Anyone on here who has constructive thoughts on this power curve, im interested to hear how you solved/diagnosed the problem. As you can see it drives as it should up to 5500rpm, then makes 120rwkw by 7000rpm. Dyno run goes to 7600rpm.
cam timing correct
3" straight exhaust
3" metal intake
ignition timing correct, and checked maintaining its set 20degrees at 6500rpm
splitfire coilpacks, no misfire
e85 sucrogen
AFRs been tested between 10:1 and 12:1, using two widebands, no change
Boost tested between 16 psi and 22psi, no change
No boost leaks
No blow by
Compression is even
two dynos, 3 tuners, remapped from scratch 3 times using power fc and nistune
water temp and oil temp are normal
Edited by Dave.TAS
https://www.sau.com.au/forums/topic/429392-120rwkw-7000rpm-rb20/
There is a restriction somewhere, and a bad one by the looks of it, but with such little information to go by it makes it very hard to help find the cause. Didn't the tuners offer a reason?
Can you post pics of your setup perhaps?
yeah my vote is for a boost leak or weak valve springs....
it looks to me like the whizzer can supply the pressure but not the volume up top. if there is a smallish boost leak, the wastegate wont open untill the correct pressure still- but the poor ittle whizzer is working overtime to supply the engine and the leak. same thing can happen with blowing open valves, eg weak valve springs.
the last boost leak I found on the gtr wasn't to be found on the dyno... but as soon as I hit the track I found it.
Cheers
Justin
Mine was more related to movement... the sudden application of torque moved the engine more than when on the dyno.
It was very supprising to me. I had all really good quality clamps, trust pipe work, trust silicone, all rolled edges at each connection.
... this is a tough one
Cheers
J.
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
