Hi all,
just want to know if anyone has any experience using a kanebo chamois?
I think it's been renamed to AION or something?
Having a black car, it's very hard to dry the car and not leave SOME small wet spots that are noticeable on inspection (as most of you would know, especially if you own a black car). Even after drying the car, it's inevitable to have water drip down from the windows or crevices lol.
ANYWAYS, my chammy has been used to the point that it no longer even dries. It's horrible lol.
So i just did a quick google search and found the Kanebo ones, and I heard they're pretty good, and from Japan. Can anyone confirm?
Found it for $18 on ebay, which is cheaper than the $25 Meguair's one from supercheap lol.
http://www.ebay.com.au/itm/260786221331?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
https://www.sau.com.au/forums/topic/429409-kanebo-chamois/
Mate, I use Bowdens Own microfibre chamois; they make a bunch of different sizes, and the big one is farkin' huge!
They glide really smoothly on my paint; no grabing, which means it can't be doing damage.
I also have a Black car; and the NM/V series Nissans have notoriously soft paint.
I reckon the bigger the better as you have to do less wipes. It's not cheap at $44 but it's more than twice the size of the Meguiars ones.
Link; http://www.bowdensown.com.au/super-bloody-huge-chamois
https://www.sau.com.au/forums/topic/429409-kanebo-chamois/#findComment-6947924
From a size perspective, I'd use a large Bowden's Microfibre on horizontal surfaces; but on vertical surfaces (close to the ground) smaller ones are safer IMHO.
Dead right Terry; I use mine fully open on the big flat panels, but folded on the sides.
Great minds eh? :whistling:
https://www.sau.com.au/forums/topic/429409-kanebo-chamois/#findComment-6951102
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
