Ok, so after buying my 32 gtst the clutch was for for about a month of very little driving.
Recently I lost pedal feel, it will only come halfway back up, and wont fully disengage when the pedal is at the floor.
It has a new master cylinder and I have replaced the slave 3 times now.. all end up leaking. The last one started leaking and scored the bore of the slave and metal shaving were coming out.
The dampener has also been removed previously.
It has a 5 Puk Ceramic button clutch.. I dont know if that has anything to do with the slaves dying (they last around 10 minutes of driving).
Any suggestions would be great..
Edited by teteous
https://www.sau.com.au/forums/topic/429411-r32-slave-cylinder-failure/
Standard clutch line? May have a leak in the hose somewhere?
Yeah, it has the metal line from the master down to the standard rubber line straight onto the slave.
There is no visible leaks on the line at all, bled both master and slave to where it will feel good, then just deteriorates the more you drive to the point where you are just slamming into gear (whilst rev matching).
The slaves end up pushing out black black grease, and when I remove the reservoir cap it seems to have a vacuum seal and bubbles will come up (even though it had been thoroughly bled, even with a vacuum bleeder).
Edited by teteous
Check the obvious things, snapped throw out lever, broken pedal etc.
So many slave cylinders is just crazy.
I checked the pedal when checking for master cylinder leaks on the inside of the firewall, no leaks there and the pedal seemed fine..
Any way of checking the throw out lever visually?
The pivot ball is not bent and looks fine.
Remove the rubber dust boot and have a look in there with a torch.
The fact that the pedal is staying down suggests the throw out lever isn't returning fully.
The Skyline clutch pedal return spring goes over centre which actually helps the pedal to go down.
Without full return from the slave, throw-out lever etc the pedal won't come back up.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
