Hey, im Bailey Gillingham im turning 15 soon and i am really stuck into cars going sideways. My favourite car is a R32 Skyline GTS-T, i will have enough money for one by the time i am 16 years old and my parents will chip in too. I plan to be in the D1NZ drift team for New Zealand as for that i where i live. I love drifting, as i have only been on a go kart drift track, i do not have nearly any experience in a track car. So lets get onto the topic, quick.
2 DOOR MODEL!
I want to put in a rb26 engine and rb25 tranny in to provide more horsepower and tourque than the stock rb20det that it comes with. I want atleast 550 horsepower. I also want the "Do Luck" bodykit. Type d1 front fenders. 50mm rear fenders. No wing/spoiler. Carbon tt style bonnet. The rims i am thinking of are Work Meister S1R in black/chrome color. I need help on the right offset ?x?. I want the whole car gloss black :).other stuff like a cage, sparco sprint 5 seats, harnesses bubble shift knob, hydraulic handbrake 3/4, bee r limiter and more. I want the car to be close to slammed! I do NOT want to be a ricer...haha so if its too much body work i can cut down to no body mods :). Turbo kit i found was the t88 33d kit by trust and it holds quite good power, single turbo. I have a few pics to show the parts etc thank you guys and girls. I have had my heart and mind set on this project for about one year and my budget would be about $30,000.
PLEASE REPLY TO THIS AND GIVE YOUR OPINION thaanks
https://www.sau.com.au/forums/topic/429414-r32-gts-t-future-build-rb26/
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
