A couple of things for the restaurant on the day.
  • All drinks are to be purchased from the bar and not put on the tables bill.....just to make things a little easier when working out the bill.
  • I have not organised a fixed price menu so you can order as you want from the menu.
  • Bill splitting can not be done so please keep a note of what you have ordered........billing can however be split up between cash/credit card and eftpos for the whole table though
cheers
Craig
Nice work Craig!
correction....sorry guy's
cheers
Craig
Hey mate bpay details are as follows
Payment details B-Pay Biller Code: 49502 A#: 5430600021458423
although jetwreck did say he was suppose to finalise numbers on wedsday i hope u can still come along man.just look through the conversation for meeting point..
Cheers
Cheers mate, paying now for Amanda and myself.
  • Receipt number
    N091935105987
Hello Everybody!!!
Well it looks like I'm left to make a decision so here goes:
Sunday September 29th we shall go for a cruise up the Old Pac, then dinner at Trackside in Gosford.
**if its all good with Jetwreck we can meet up at Lanecove at his under ground car park for a pre-meet and then head up the coast, about an hours drive...
ball park time of 10:30am meet up and leave at 11:30-12:00 and get to Gosford at 1ish for a feed.
if the mod's wouldn't mind updating the first post that would be great!!!
Thanks, Theo.
Want to do mine while your at it?
Well, I got a full day. So we can see how it goes? :D
Just ahhh leave the keys yeah? ;)
Just make sure you chain your zorst and turbz to car otherwise they'll go missing :P.
Edited by M35woah
Hey all,
I accepted of FB but havent been around as I had some spinal surgery and hope to be there on the day and of so Sinful maybe come as well if not have a great safe day.
Im not going to argue with that
you coming up to Sydney first? If so I might get you to leave 30 minutes earlier from Lane Cove with the PNM35's so we all arrive at the same time!
  • Like 1
Hahahhahahahahahahaha living upto "the world biggest shitstirrer" title i see. Edited by Howaitonaito
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
