Hi guys, Im currently under going a new build on my R32 GTR with the build aimed for a little street use but mainly the drag strip. My main worry at the moment is spliting the standard block. Has anyone on here had any experience with half grout filling of RB26s and any reports of running temperatures and any other feed back would be great!!
Cheers Simon.
https://www.sau.com.au/forums/topic/429446-strengthening-a-rb26-block/
All ready spent the money on having this block treated and machined. Not to keen on forking and doing it all again hence the reason I want to know if anyone has half filled them. Personally I think it will be stronger then a N1 and I cant see there being a problem with overheating but would be good to hear from someone who has actually done it.
Majority of the temperature comes from the cylinder head anyway. You should have no problems filling the bottom end up to around 1/3. Call up some race engine builders and talk to them about it.
Josh.
I have a reasoably stout set up in my GTR.
I chose to keep the standard matching numbers block in my car.
My aim is over 500rwkw, so I chose to part grout fill my block. If it's a street car, you will need to plan your cooling system very carefully. Most of they guys I have spoken to with grout filled blocks run a stock water pump with the stock pully.
I have also chosen to use a specialised coolant and twin pass radiator.
Cheers
Justin
I've just done the same (Hardbloc to bottom of lower welch plugs) with my 30/26 build. Will wait and see what affect that has. Being that low it shouldn't have too great an affect on cooling but hopefully just enough to lock everything together a bit down the bottom where they normally split the block.
It actually makes the cooling process more efficient.... however, your oil temps will go up as a result of no lower block cooling.
The main issue is loss or coolant volume.
Cheers
Justin
Thanks for the feed back!! XRATED have you done much driving in yours to see how the temperature sits? I was planning on going to the top of the welch plugs which is pretty much half. Obviously im also running a large oil cooler and koyo radiator which will also help.
Mine only has an issue when at idle and/or low revs/low speed. but I'm using an N1 water pump and under drive pulley. I knew I was going to have an issue, but I wanted to experiment with it.
I have a Racepace twin pass rad, with the stock clutch fan/shroud... but the N1 pump just can't flow enough water at low engine speed, especially with the under drive pulley.
If I was running e85, I might be able to get away with it??? as combustion temp's would be lower.
I know of 3 high hp rb's that are hardblocked up to the welsh plugs (going above the welsh plugs is a lot harder) that run perfectly cool at low speed with the right set up.
Cheers
Justin
running hardblock to bottom of the welsh plugs. n1 pump (no underdrive) & 50mm radiator. No cooling issues at all with street driving, car warms up quicker, but normal temps are the same as before engine build
Have had 2 blocks. Both filled at least 1/4, no temp issues to speak of.
Both were street driven with N1 water/oil pumps & using a decent tri-radiator (once was Racepace, one was Race Radiators) both @ 360-380rwkw.
Ambient temp - 20 degrees
Water temp - 70-74 degrees. heavy traffic 78
Oil temps (inc oil cooler) - constant 80-82, wouldn't budge
Won't be a problem IMO for daily driving as power isn't really relevant when putting around in traffic.
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
