I am almost ready to put my new rotors, calipers an brake lines on my 32.
I had my 33 front calipers professionally rebuilt an painted my the car was in at the workshop last year (they aren't on the car yet). I pulled them out of storage on the weekend and found certain parts of it missing!
The bolts that go across the opening on top, where you'd see the pads come into contact with the rotors, are missing on both calipers. As well as the lil spring steel plate/shim that goes there too.
What I was wondering was, is there any other parts in that top area besides the pads, bolts an shim?
Would my 32 type m caliper donate it's ones or is it not compatible?
The workshop also lost the bolts for my radiator panel -__- their work is really good but I'm still not impressed
Any advice or help will be appreciated :-)
The workshop lost them, but I have to shoulder some of the responsibility too, since I failed to check if they were in the box the calipers were returned to me in.
I only noticed last night and was hoping that it maybe a common knowledge thing, cause I have to fight to get the skyline into the garage to work on it lol. One garage space, four cars, four opinions on who gets the garage.
Yeah I know the feeling, I lost the centre caps to my wheels, forgot about them at the tyre shop.
Hmm, you can always crash into their cars then say "should have let me fix the brakes before when I wanted to" :P
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
