hi guys ,, i hav ma car write off in accident 1993 skyline gtst, wanna sell the whole lot for $4000,, main damage on back.. lil on frnt. car still drivable, any insecption welcome. many quality parts in car.. like greddy coilovers type r or s not sure 32 way adjustable, jimm berry clutch over 300++ rated, head recondition with hks big cams, 264, new head gasket, trurst turbo cat back exhaust, front dba slotted rotors, hicas locked, new castor rods adjustable put 2 weeks ago. aftermarket thick radiator. gizmo boost controller, standrad trubo with 3 inch dump pipe, car running well and smoth always service wid motul oil, only lil prob with gearbox hav little clunck in 4th gear.. rest all fine. price nego... if i cnt sell it i will apart the car and sell parts,, my contact number 0431318150. i am located in narre warren victoria.
sum pics included abt damage on car.. post-58597-0-38037300-1375136970_thumb.j
post-58597-0-32615300-1375136997_thumb.jpost-58597-0-33994100-1375137069_thumb.jpost-58597-0-36588700-1375137094_thumb.j
https://www.sau.com.au/forums/topic/429467-1993-r33gtst-wrecking-whole-car/
this the mod lisit on car ...
recondition head with arp studs and metal head gasket, with hks 264 cams, new lifter , seals and valves..
r34 gtt stock intercooler
new castor rods adjustables, 2 week old
splitfire coilpacks
trust cat back exhaust with venom high flow cat
stock turbo 3 inch dump
bosch high flow pump 500hp+
jimberry racing clutch 300kw + rated, never drift or draged
new timing belt and bearing kit installed last service
trust type S coilover fully adjustable perfect condition
hicas lock bar
apexi boost gauge
HID lighht kit
Dba frnt solloted rotors with premium bendix pads
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
