1995 - R33 GTST Skyline Series 2
Very reluctant sale.
Serious buyers only, no time wasters please. Plenty of modifications with engineers certificate as a 4 seater.
180XXX Kilometre’s
269 Kw on HI boost (14.5psi) can go higher.
Upgraded Turbo: Garrett GT 3076r Turbo
Apexi Power FC with Hand Controller
Tein Adjustable Suspension
Turbosmart E Boost 2 Boost Controller, Low-Hi @ 12-14.5 psi
Veilside Body kit
18” Advan mags
Front Mount Intercooler
Pod Air Filter
Split Fire Coil Packs
Upgraded Fuel Rails
3” Exhaust
HICAS Lock Bar
Heads up display, displasy either speed or revs
Front Camber Kit
Slotted rotors front and back
Momo Steering Wheel and Gear Knob
Alpine Double Din with 6 disc stacker
Alpine Splits at the front, 6x9 rears, Kicker sub, and two amps
Oil catch can
Shift Lights
Turbo Timer
Two spare Rims with tread.
Engineer’s Certificate for all modifications.
Have receipts for most modifications
Tuned at ESP
If more photos or info are wanted please let me know... [email protected]
Looking for $10,000 ono must sell.
https://www.sau.com.au/forums/topic/429485-1995-r33-gtst-s2/
Price drop $8500
Yes they did, this would be a series 1.5 seeing as they're not series 2 headlights as well.
Yep, plus the interior and the lack of Airbag also.Never seen this car around... GLWS!
Yes as the Skyline gurus have pointed out, its a series 1.5 as I've now found out?? Didn't really know there was a1.5? Only had one airbag in the steering wheel, does have the series 2 neon "Skyline" on the boot, plus the boot lock cover.
The reason you haven't seen it is because its been sitting in the garage for about 12 months or more. I have work car that's a bit cheaper on fuel for me..
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
