My r33 gtst has standard shocks and the springs are cut. I am in the process of changing suspension bushes cause they are stuffed and steering is really bad so i am considering doing the lot (springs and shocks). I already have a set of king springs at home i think they are 140mm lower than standard ride from what i gathered... Not sure about compression or anything... What is a good value set of shocks to get? i dont want to spend a fortune but just want to get a set of good quality ones that will keep my car low, and not be 2 bumpy for street use like my chopped springs.
Sorry for the long post any help appreciated...
https://www.sau.com.au/forums/topic/42950-shocks-springs-what-to-get/
140mm lower than standard are you sure dude that is way low, well actually you would be dragging a fair bit of stuff :uhh:
How much do you want to spend is the question to ask your self, bilsteins are about $900 for the four, not to hard pritty good for street use. You could get KYB's for a bit cheaper don't know what these would be like though, they are about $750 for four.
If you lower it a fair bit you are going to need alot of caster and camber dialed in.
What sort of bushes have you got.
At the moment my camber is stuffed bad. My insides of the tyres wear out before the outside is even started. maybe it was 40 mm lower not 140... Intending on spending approx $1000 not much over that. at the moment the car is like 3" lower than standard so its a pretty rough ride and the M-spec bar sits about 1.5 inches above the ground.
I doubt you'll be able to get a set of springs and shocks for that price. Unless you go for second hand. Just Jap has some second hand suspension at the moment on sale. Check out www.justjap.com but be aware that these are usually coil over packages and may not improve the comfort factor.
Otherwise get a good set of springs that aren't too low. Like a set of low kings and keep the factory shocks until you can afford new shocks. You'll probably find your bumpstops are rooted and need to be replaced as well.
try UAS..
mention SAU member (have you joined yet?) and you will get some discount.
Bilstien -> 225 x 4 = $900
whiteline spring -> $2~300
so should not too far from $1000..after discount
Sorry Boro, I could not get the RSM at this stage, something need to fix first.
I already have a set of king springs as mentioned in 1st post... Im not too fussed about a bumpy ride as most lowered cars are like that. Just when my car bumps it rattles everything inside it and the window's etc. My mates S15 silvia is low but when he hits bumps the it bounces off them smoothly rather than my banging etc... I am not after a standard set up and intend to keep the car low.
But it doesn't have to be that way, you can have a nice ride. :aroused:
Just choose the right components in the first place. It doesn't cost more either. Sidewaymambo posted the right suggestion, Whiteline springs and Bilstein shocks. :P
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
