So I was on Parramatta Rd today looking at some GTR's when I noticed a beautiful white Series 8 RX7 sitting in the lot. I sat in it and was instantly reminded of the MX5, with it's cockpit-like interior and snappy gearbox.
I've always been fond of the RX7, however I am hesitant to buy anything with a rotary due to hearing bad things and having no experience with them. However, all I would ever want is to buy one completely stock and not even touch it, so really, how unreliable could it be?
Keen to hear your thoughts and experiences on the VIII RX7 and just rotaries in general.
https://www.sau.com.au/forums/topic/429501-i-kind-of-want-to-buy-an-rx7/
I did a bit of research on these before and it seems like if you keep the series 8 near to stock then they are a great car. If you go for an early series FD then there are a few things that need to be modified to make even stock ones reliable. Although by now, after 20 years of use, I imagine even the early ones would be sorted out.
At the end of the day if you do blow a motor you can get a kit from the US to stick an LS1 in there and they only weigh a little bit more than the rotary.
Just make sure you put NO2 bottles in a secret compartment under the seat so that for 10 seconds or less you can be free :P
  • Like 1
I know a guy thats been racing stock series 7 or 8 rx7's for years at targa and club days and never had any reliability issues. All comes down to how well they have been maintained and luck.
How much would it cost to rebuild a rotary anyway?
I had a series 8 for a few years and never had any major issues with it at all. The engine remained stock but it did get driven pretty hard. It did the 600km run from Perth to Kalgoorlie at least half a dozen times without it missing a beat.
That being said, they are the kind of car that loves to be driven hard, so finding an unmolested one will not be that easy. Whatever you do, do not believe the odo on these cars, a massive amount get wound back.
Someone called?
Rotaries are awesome and don't let anyone tell you otherwise - I have 2!
If the engines are looked after, built well (if modified), treated properly, warmed up etc. they are definitely reliable.
I have an FD 5-speed in one of my rotangs running ~375rwkw on pump fuel and it holds up and shifts well, doubt it could take much more but I don't think you'll be pushing that with your normal 13BT.
Someone called?
you have two? is that so whilst one is being repaired you can drive the other? (jokes)
Someone called?
But that's your only "running" rotary innit?
It is but that's only because I bought my FC without an engine in it ;)
:P
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
