Traction Tyres have been really good for all my suspension work, both the GT-T and R
the installation i would imagine can be done anywhere, but the alignment is what you want to make sure is done properly.
Traction Tyres is in rowville, but probably only 30mins from moorabbin. Straight down north/wellington rd, turn left at stud i think, right into Kellets. you're there.
They look after a lot of SAU cars
car tech in dandy for alignment or the above ^
install it your self ?
unbolt oil lines, cut the hard lines then loop an oil hose on it, remove rods from hicas rack by clamping it on a vice bench and removing with a big shifter .
install rods on lock bar, bolt it up , top up power steering oil and get an alignment
Edited by Dan_J
Yeah I wouldn't recommend doing it unless you're not too far from a tyre place that can align it... When I did mine my Rear Tow was out by something like 25mm? Not extreme, but not great for tyre life either ;)
If its aligned by eye, it should be drivable to get it done properly... Problem is most of the ebay ones are a bit out, most aren't 100% the same...
It won't drive straight until I get it aligned though will it? So it'll be a pain to get anywhere to get it aligned
its not that bad. its a funny feeling though when its all out of wack. just drive it slow.
If you want it all fitted up i think racepace supply and fit and they are top quality bars from what i hear, nice blokes too
Most of them have got a basic jig made up, they hook the two brackets over pegs measured out at the right distance, lay the bar across it and get welding... Normally the brackets are a mm or so out in a random direction, but because of the pegs the bolts still fit fine, and the variation can be adjusted back out with an alignment.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
