Hello,
I bought some ARP head studs (202-4207) for my RB26. However I am a bit confused as I am not sure which torquing procedure I shall follow best.
The Nissan torquing procedure for head studs is:
1. Tigthen to 29NM
2. Tigthen to 108NM
3. Loosen to 0 NM
4. Tighten to 25-34 NM
5. Tigthen to 103-113NM
However the ARP manual states:
Following the manufacturers recommended torque sequence tighten the nuts in three equal steps to 105 ft lbs / 142 NM
with ARP ULTRA-TORQUE FASTENER ASSEMBLY LUBRICANT.
So should I use the Nissan torquing procedure but torque to 142NM instead of 103-113NM in step 5 or should I follow the ARP procedure (three equal steps to 142NM)?
Don't tell me to ask ARP regarding this case as I wrote them already two messages (one 10 days ago, another one 5 days ago) and no one bothered to reply to me.
So their customer service doesn't seem to know the solution.
Thanks!
If the engine was built from scratch, as in torque plate bored/honed with the studs at their ideal torque etc etc then I would use the arp tensions as they make the stud and know what torque is required to achieve proper stretch plus the machining was done to suit that tension.
However, if you are just putting some studs in your standard engine to replace the bolts for whatever reason then I would go no more then the standard torque. The problem you might have is the bores will be stressed in a different manner now and they will most likely go out of round (even if only slightly) with more torque pulling the head down harder.
I used ARP specs but I admit, my bore is floating so doesn't suffer from the 'out of round' associated with solid blocks. Clamp the sucker down tight was my motto, 96nm ftw. :)
I followed ARP specs on 2 motors I have used them on, but did tighten then slack off process for OEM gasket. No torque plate hone on either motor, one with MLS HG other with OEM crush type. Both motors since faultless.
I prefer the ARP method as the OEM method is intended for two things: to crush the gasket and then torque, and to allow bolts to stretch. The ARP studs stretch far less and are reusable, so the torque settings are not relevant and 3 steps is better for even torque when not expecting bolts to stretch. If you are using an MLS gasket the tighten then slack off process is also redundant as you don't need to crush the gasket before going for final torque.
In the case of using an OEM gasket go to 30/65/100nm, then loosen off and go 3 increments of 47nm. I wouldn't be afraid to go 3 increments of 50nm (50/100/150) to allow for tool slack.
If using an MLS probably stick to 4 increments of 47nm if you have good tools.
it's not just to crush the gasket the multi stage. It is to also seat the head of the bolt onto the surface below it, in order to get a more accurate torque reading. Can't remember the exact link, but it was from an unbrako catalogue (they make high tensile bolts)
How do you figure the ARP's stretch less?
I would follow the ARP method as closely as possible including lube type etc. The relationship between pre-tension and torque is obviously very sensitive to friction but also things like tightening speed etc.
I will be using a Metal Head Gasket. I removed the head to seat the valves, the block will stay untouched. GtScotT, you mean three and not four increments of 47NM (3*47NM=142NM)?
Still there doesn't seem to be a consensus here regarding this matter...
is the hread pitch on either end of the stud different, if so(i think they are)torquingto nissan specs with lubricant will increase the headgasket crush by about 50%
The final torque recommended by Nissan is lower than the one by ARP. So how come that the head gasket will be crushed more?
What he is getting at (I think) is you need to think of clamping force and torque differently. a finer pitch thread will produce more clamp force at tge same torque setting as a coarser thread. just like if you dont lube up the bolt, it will lose alot to friction and produce far less clamping force.
I'm just putting things into simple terms. The ARP's are not torque to yield like the stock bolts are, so the easiest way for me to have described WHY they take more torque to the OP was to say that they stretch less. While that may or may not be entirely accurate it is a reasonable way of thinking of it. ARP themselves describe stretch yield to be 5 thou as a rule of thumb, so if considering that as a base the ARPs must stretch less at a given torque, to take more torque than the stock torque to yield bolts and not exceed 5 thou.
Clearly I am not taking the metalurgy of the bolt or its elasticity into consideration as it is hardly important in answering OPs concerns.. The point is that the specs for torquing them are higher than stock and OP should not be concerned.
Yes I do mean 3 increments of 47nm. So in the case of using a MLS HG I would sit the head onto the block and use the factory torque down order, 47, then 94, then 142nm. Double check the last increment and make sure you are pulling the tool towards you, slow. Do not push the tool away when torquing. Steady your body and use the motor and your strong arm to pull towards.
Your comments about stretch to yield are very misleading. Broadly speaking the point of using higher grade fasteners is to increase pre-load. ARP are a very high grade fastener (up to 1500MPa UTS) so to hit the higher pre-load the torque is higher. Two bolts of differing grade will stretch the same amount for a given pre-load (assuming equivalent geometry), it's just that the higher grade fastener is capable of a higher pre-tension before you exceed the proof stress. A rule of thumb for stretch ignores the biggest factors driving elongation which are 1) length and 2) pre-load/stress.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
