hi all i have some leftover parts from my s13
standard tail lights perfect condition complete with bulbs and all $70
180sx headlights with motors and covers in good working condition, $150
180sx 25mm widebody front gaurds in average condition$50
180sx bonnet in average condition very small dints and has been sanded for paint$100
also have a complete (front bar, rear bar, skirts) brand new never fitted supermade instant gentleman bodykit (not genuine) paid $900 take it for $700
OP6/ VQ30 turbo with hks 1bar actuator good condition next to 0 shaftplay $300
rb25 long motor with low compression 130-135 across all 6 has blow by issues still in the car running suspect just very worn not cracked pistons given the even compresion so could probs get away with rings and bearings rebuild$500
s13 sr20 non turbo motor was running well when removed from car comes with complete loom and ecu and auto gearbox$400
brand new never used greddy emanage blue $350 can have map sensor and r33 patch harness for extra $100 selling due to change of plans
black s15 factory wing with brake light and wiring$150
driftworks s13 rear lower control arms used$150
most parts are located in brisbane northside some are in bundaberg can arrange to bring parts down from bundy on weekends and maybe deliver to some where between bundy and brissy best bet to msg me and arrange from there
feel free to ask any other questions all prices are negotiable can text pictures of most parts if you want
would be best to call or text me on 0434 879 399 as im not on here very much
Andrew
https://www.sau.com.au/forums/topic/429539-qld-rb25s13-parts/
let's talk serious on the emanage blue...not the most cutting-edge pice of kit, but how much you really chasing for it and the r33 plugin harness?
feel free to make an offer still have all of this needs to go asap
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
