hi all i have some leftover parts from my s13
standard tail lights perfect condition complete with bulbs and all $70
180sx headlights with motors and covers in good working condition, $150
180sx 25mm widebody front gaurds in average condition$50
180sx bonnet in average condition very small dints and has been sanded for paint$100
also have a complete (front bar, rear bar, skirts) brand new never fitted supermade instant gentleman bodykit (not genuine) paid $900 take it for $700
OP6/ VQ30 turbo with hks 1bar actuator good condition next to 0 shaftplay $300
rb25 long motor with low compression 130-135 across all 6 has blow by issues still in the car running suspect just very worn not cracked pistons given the even compresion so could probs get away with rings and bearings rebuild$500
s13 sr20 non turbo motor was running well when removed from car comes with complete loom and ecu and auto gearbox$400
brand new never used greddy emanage blue $350 can have map sensor and r33 patch harness for extra $100 selling due to change of plans
black s15 factory wing with brake light and wiring$150
driftworks s13 rear lower control arms used$150
most parts are located in brisbane northside some are in bundaberg can arrange to bring parts down from bundy on weekends and maybe deliver to some where between bundy and brissy best bet to msg me and arrange from there
feel free to ask any other questions all prices are negotiable can text pictures of most parts if you want
would be best to call or text me on 0434 879 399 as im not on here very much
Andrew
https://www.sau.com.au/forums/topic/429539-qld-rb25s13-parts/
let's talk serious on the emanage blue...not the most cutting-edge pice of kit, but how much you really chasing for it and the r33 plugin harness?
feel free to make an offer still have all of this needs to go asap
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
