Sarcasm? haha I don't really have set days that I must work out on.
I usually do every second day then a couple days rest, if I have an extra day rest or miss a workout the next week will fall on a sunday.
Nice work man, keep it up.
EDIT: Realised this sounded contrived, my point being even with discomfort you had a god and got through it for the most part.
Edited by ActionDan
Thanks, what's a rajab? haha I see it everywhere. Swear filter?
It's always an internal battle as to whether I should push through the pain or if I should stop. I'm slightly wiser now so I stop if I have to
Edited by r31slpr
Hip still playing up a bit, hurts in the bent row position, should clear up soon.
Had to walk to the gym today...First world problems haha
20/12/2013
Lunge: 1x8 Bar
3x8 @35
Bench: 1x8 Bar
1x8 @20
3x8 @30
Row: 1x8 @40
3x5 @55 Difficult holding the right position for this.
Pullups: 4 :angry:
Nice deading.
There's a good explanation of Rajab over in the motorsport section.
Essentially it's just an "in" joke from some of the Wastelanders praising Rajab (the engine builder/performance workshop) for anything good that happens any time.
Thanks, it ended up being 4 sets of 2 reps because I did 2 stopped for chalk, did 2 more noticed my leg was bleeding haha tied my towel around it, did 2 more, then decided I may aswell do another couple .
Thanks for the rajab explanation, a lot of stuff makes more sense now haha
Indeed.
25/12/2013
Lunge: 1x8 @20
3X8 @40
Mp: 1x8 @20
4x5 @32.5
1x5 @22.5
Row: 1x8 @50
4x5 @57.5 Will probably stay at this weight for a little while because hip is still hurting in that position.
Pullups: 4,2,2,2
Had a few days off, shoulder is giving me grief again.
Rows went to shit and decided not to do dips.
Will go see the physio as soon as possible.
31/12/2013
Lunge: 1x8 @20
3x8 @40
Dead: 1x5 @90
1x5 @110
2x3 @130
Row: 1x8 @40
1x5 @50
2x5 @40
  • 3 weeks later...
Alrighty couple quick updates.
Haven't seen the physio yet just been working on the shoulder myself.
Got told the other day I'm supposed to include the bar weight in my lifts, so all my previous ones are just the weight that was on the bar not including the bar itself. All future ones will be total, weight + bar.(which I believe is 15-20kgs)
The above doesn't really matter because I've changed to an entirely new program and dropped all my lifts down to about 40kg to start with as its higher volume.
Not sure if I should keep logging progress here or just put it in a spreadsheet.
  • 10 months later...
Long time no update. Still lurking here though
Joined a new gym about 2 weeks ago, did 1rms.
27th Nov: Squat 185, Bench 100, Dead 200
Worked on technique
2nd Dec: Squat 205
3rd Dec: Bench 110
6th Dec: Dead stayed the same, had a shitty day
  • 1 year later...
Been nearly three years since I started this thread. Started out injured, got a fair bit better and stronger for a while. Since then its been all downhill.
Been plagued with injuries for ages, either work related or just because I'm an idiot.
So back to basics.
The ptc beginner program is the only one I've done so far that I consider to have worked well (ie: got stronger & didn't get injured) and that's what I'll be doing again until I stall.
Hopefully it will put me in the right direction.
16/05/2016
Squat 3x10 Bar + Split squats 3x8 Bw (needed to stretch my legs a bit)
Bench 3x8 Bar
Row 3x8 Bar
Ohp 3x8 Bar
Rdl 3x8 Bar
Curls 3x8 Bar
Progression will probably be daily till that slows down, then weekly for as long as possible.
Going to try and update here as I go
  • Like 1
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
