Still going just forgetting to update
08/08/2016
Squat   3x10 92.5kg
Bench  3x8 80kg
Row     3x8 80kg
Ohp     3x8 52.5kg
Rdl      3x8 92.5kg
Curls   3x8 17.5kg db
10/08/2016
Squat   3x10 92.5kg
Bench  3x8 80kg
Row     3x8 80kg
Ohp     3x8 52.5kg
Rdl      3x8 92.5kg
Curls   3x8 17.5kg db
12/08/2016
Squat   3x10 92.5kg
Bench  3x8 80kg
Row     3x8 80kg
Ohp     3x8 52.5kg
Rdl      3x8 92.5kg
Curls   3x8 17.5kg db
15/08/2016
Squat   3x10 95kg
Bench  3x8 82.5kg
Row     3x8 82.5kg
Ohp     3x8 55kg
Rdl      3x8 95kg
Curls   3x10 17.5kg db
18/08/2016
Squat   3x10 95kg
Bench  3x8 82.5kg
Row     3x8 82.5kg
Ohp     3x8 55kg
Rdl      3x8 95kg
Missed a day last week. Things are definitely getting harder now, especially because I'm still attempting to cut.
Ohp is suffering, so attempting a few different things to see what works. Open to any suggestions. Dropping rows down a little this week.
21/08/2016
Squat   3x10 97.5kg
Bench  3x8 85kg
Row     3x8 80kg 1x12 1x8 60kg
Ohp     1x8 60kg 2x8 1x4 50kg
Rdl      3x8 97.5kg
Did something to my leg so no lower body till it heals.
24/08/2016
Squat
Bench  3x8 85kg
Row     3x8 40kg dbs cant do bb at the moment because of leg
Ohp     1x5 60kg 2x10
Rdl
  • 3 weeks later...
Been crook for a few weeks. Still not fully recovered.
Lowered the weights till I'm feeling better.
12/09/2016
Squat 3x10 80kg
Bench 3x8 67.5kg
Rows 3x8 67.5kg That's all I had in me.
14/09/2016
Still not great, this took me ages to get through.
Squat 2x10 80kg
Bench 3x8 67.5kg
Rows 3x8 67.5kg
Ohp 3x10 40kg
Rdl 3x8 80kg
Curls 3x8 15kg db's
20/09/2016
Pretty much the same as last time, feeling better now though will add weight next session.
Squat 3x10 80kg
Bench 3x8 67.5kg
Rows 3x8 67.5kg
Ohp 3x10 40kg
Rdl 3x8 80kg
Curls 3x10 15kg db's
Been squatting in work boots lately, the heel makes it much nicer on my knees. Going to look around for proper lifting shoes
03/10/2016
Squat 3x10 90kg
Bench 3x8 77.5kg
Rows 3x8 77.5kg
Ohp 3x8 50kg
Rdl 3x8 90kg
Curls 4x10 15kg db's
03/10/2016
Squat 3x10 90kg
Bench 3x8 77.5kg
Rows 3x8 77.5kg
Ohp 3x8 50kg
Rdl 3x8 90kg
I use adidas powerlifts for squats, love them
Had a look at the powerlifts, doesn't look like they do them in my size. Usually between a 13 and 14 US.
Heel height in a lot of those weightlifting shoes isn't much better than my work boots.
05/10/2016
Squat 3x10 90kg
Bench 3x8 77.5kg
Rows 3x8 77.5kg
Ohp 3x8 50kg
Rdl 3x8 90kg
07/10/2016
Squat 3x10 90kg
Bench 3x8 77.5kg
Rows 3x8 77.5kg
Ohp 3x8 50kg
Rdl 3x8 90kg
19 hours ago, L33SH said:
Numbers are coming along!
Getting there, still trying to lose a bit of weight too. So that's probably making it a bit harder. Hovering at about 100kgs at the moment
19/10/2016
Squat 3x10 95kg
Bench 3x8 82.5kg
Rows 3x8 82.50kg
Ohp 3x8 55kg
Rdl 3x8 95kg
Curls 3x8 17.5kg db's
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
