Nope. Joining the club is cheap and easy, and then you get to come on cruises, track days, shows etc etc. Basically nothing is advertised on the public section anymore.
OK cool thank you for the info. So they advertise within the paid section of the site do they? or emails to paid members or??
If I can get the 32 to stop pissing oil, coolant and gbox oil out everywhere I'll probably enter it if SAUSA do a display.
Sounds good ok well keep us in the loop,. Considering joining the paid section if it is going to be worth it for the club display entry etc.
Is anyone who is already a member of the paid section able to tell me if they are actually planning on having a group display or nothing actually mentioned yet? (it's about 12 weeks away).
Yep once you join the SAUSA club then you have access to a new group of sub-forums at the top of the SAU page. But they also have a FB group, website and emails out. I am pretty sure they would be organising show attendance at Extreme this year.
I am planning on going in it :)
You have to wait for an admin (me) to be notified by SAUSA to add you to the SAUSA member list. But since I am a nice guy and will take you at your word, I will do it now :)
Ahhh! There we go great thanks very much :) Now to hope people want to enter this year haha :) (I see Brad's post about last years)..
Yeah I think after a bit a apathy/failure at organising last year's show this year might be a decent one! We have new Exec event coordinators, so hopefully they pump this show up and get decent attendance.
Awesome sounds great! Well i'll keep an eye on that forum section and see what comes up. So they should organize on their own back without the need for me to post in there or should I start a thread? (don't want to tread on any toes :P ) haha
There is no harm in posting a question about it in the General Club Chat thread, but leave the posting of the event and subsequent organisation up to the event coordinators.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
