NOTE: SERIOUS BUYERS ONLY
Car:
• 1994 Black R33 GTS25 Type-S
• Manual 5 speed
History:
• In 2004 by Special Vehicle Imports (QLD) with 50,000km. In the time I've owned
it I have traveled approximately 10,000km per year. When it had just clicked over
100,000 km, I had the timing belt and water pump replaced. It is serviced
by Chapman and Chapmans every 10,000 km and I change the oil, oil filter and
inspect the spark plugs myself every 5,000 km in between.
Wheel/Suspension/Brakes:
• Sparco Racing rims 235/45 R17 with 4 new tyres (99%
tread)
• Whiteline springs with modified circlip height adjustable Bilstein shocks
(Sydneykid spec)
• Whiteline fixed front and adjustable rear swaybars
• Whiteline adjustable front and rear camber bushes
• Whiteline adjustable front castor bushes
• Whiteline pineapples
• Nismo front strut brace with master cylinder stopper
• R33 GTR rear strut brace
• Locked hicas
• R32 DBA slotted rotors and calipers (rebuilt) front with Hawk ultimate brake
pads
• R32 stock rotors and calipers rear (rebuilt) with Hawk ultimate brake pads
• ADR approved front and rear braided brake lines with Motul RBF600 fluid
Drivetrain:
• R33 GTR clutch
Power:
• Coby extractors with HPC coating, 2.5" high flow metal cat and a 3" Xforce Varex Remote Control Muffler
• Apexi SAFC-II (Black version) tuned by Matt Spry
Cosmetics:
• R34 GTR bucket seats (Incl. Modification Plate)
• Stealth rear wing
• Nismo tinted side indicators
• Tinted windows
Extras:
• CD Headunit
• Pioneer 6.5" front speakers and Pioneer 6x9" rear speakers in a custom MDF shelf
• Australian approved 3+1 immobilisation point $1000 aftermarket alarm system
(installed by Chris Rogers, will disclose if buyer is serious)
PM or Call me on: 0421714892
Edited by r33_gts1
https://www.sau.com.au/forums/topic/429583-1994-r33-gts-series-1-non-turbo/
  • 4 weeks later...
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
