I bought a pair of smoked nismo side indicators for my R34 turns out they are a 4 slot design where as my plugs are 3 slots, anyone selling 4 slot plugs or know where I could get some? Hoping they are interchangeable. Cheers.
https://www.sau.com.au/forums/topic/429584-r34-side-indicator-plugs-4-slot/
Hi Tyler - ^ have you got that around the wrong way? (R34 are 4slot and the Nismo smoked are 3slot)
34 GTT indictators are 4slot and have a longer sleeve.
Correct you need R34GTR or R33GTR indicator connector plugs (3slot)
If you manage to modify the Nismo smoked indicators to be 4slot by cutting it still will not fit as the globe and housing on the 34GTT is still too long (the globe will prevent full insertion) :(
I found out the hard way. I know have a farked set of new Nismo smoked indicators. :(
You can go to Supercheap and buy a generic insert and make that fit.
or Best solution is track down GTR33/34 indicator connectors (3slot)
Did you purchase from Kudos and what state is your new Nismo blinkers in ? Unmarked with packaging ?
Reason being is they do have post August 2000 Nismo Smoked indicators to direct fit the R34GTT (4slot), as I only found out today, after Andrew at Kudos rang me.
Quote: "The units originally purchased are actually to suit vehicles manufactured before the 08/2000 if your vehicle is after you require the ones here. Would you like me to swap them over?"
So pre this date they are 3slot and post august 2000 they are 4slot :thumbsup:
Edit: A quick thought - your GTT may be pre this date. Therefore you may have the opposite issue I had :wacko:
Edited by Sinista32
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
