Yes you can. Are you using Nistune or ECUTalk? I had some trouble seeing the VSS in Nistune last year. If you're still using an old version you might have the same trouble. Same could go for ECUTalk I suppose.
In my case I have R34 engine in R32 with 33 gearbag, cable speedo and speed signal from speedo head to ECU. So completely different to an actual R34, but the end result is the same. The speed signals from the speedo to the ECU are the same.
https://www.sau.com.au/forums/topic/429588-r34-gtt-nistune/#findComment-6952041
I was getting the engine light coming on with the error of speed sensor. I then checked the speed sensor and found that it was sending out a good signal. This signal then goes to the dash, which is then sent to the ecu. For some reason the dash isn't sending out a signal. I then replaced the dash only to have the same issue rear its head. I have since put the original dash back in and the error has gone away after being cleared and has not come back, but the speedo in ECUTalk still isnt working. I haven't checked the output from the dash yet.
So to confirm you are running a wire straight from the speed sensor on the gearbox to the ECU (Pin 29?)
https://www.sau.com.au/forums/topic/429588-r34-gtt-nistune/#findComment-6952062
No. That won't work, even if you have an electronic sender (which I don't, as I have cable drive speedo). The electronic sender puts out an AC saw tooth signal. The speedo head puts out a 0-5v square wave. Not compatible in the least.
If you need a thorough test for your speedo signal out of the dash, get a hold of a portable oscilloscope and hook it up to the VSS pin on the ECU and see if you can see the signal while driving.
https://www.sau.com.au/forums/topic/429588-r34-gtt-nistune/#findComment-6952099
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
