Hey,
I just purchased a 1995 r33 gtst for the missus, and its having an issue where is randomly cuts out. It can be when cold or hot, WOT or idle. Some times it last 1 or 2 secs, and a few times it has lasted 10 secs. Sometimes its very often, other times it can go 25 mins without any issues.
So far I have checked the error codes. It came back with a 12 (AFM) . I pulled it out, still had pod adapter on so wasn't bolted to airbox, and was filthy. I cleaned it and bolted it to airbox. Looked to be fixed but once again it eventually started cutting out again.
I'm thinking its not the AFM any more, as its a solid cut, like ignition cut.
I've read a lot of people saying the CAS but the previous owned said he replaced it (was with a 2nd hand one though).
Any ideas before I have to buy a new CAS?
https://www.sau.com.au/forums/topic/429600-r33-cutting-out-randomly/
Could be loose / dry solder joints in the AFM? could explain intermittent randomness.
There is a DIY fixup thread around here somewhere...
ahh, there it is. --->> Click this!
Should be along the same lines for RB25.
Had the exact same issue. What I did was clean my afm entirely, took the four screws out and took off where the cable plugs into (realised I shouldn't have done that because it broke the solders)
Ended up cleaning it with contact cleaner and resoldering it back together.
Took off AAC valve as I found out they fill up with carbon, gave that a hit of contact cleaner and got scrubbing with cotton buds.
Unplug the purple and brown plugs near the centre of the firewall and spray some more all over the contacts. Also spray contact cleaner on the afm plug. I basically did them all at the same time so I didn't work out what was the main culprit butit mostly was the afm... good luck
So you think the AFM could cause the ignition cut if there is a faulty connection? Because I was starting to think it wasn't AFM as it will run without the AFM plugged in.
The ECU error is still saying AFM though, So i might have some faith and follow your instructions.
At first I just sprayed through the airbox onto the sensor and it fixed for a couple of days but then it started cutting out again. So yeah I ended up breaking the original solders unintentionally which I soldered back up and while I was able to get to all the shiny bits inside I flooded it with the CC, put it all back together and it's been fine since. No hint or anything. There's DIY thread on here somewhere and I just followed that.
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
