not exactly the same as yours but I installed a fmic on mine and everything is fine. After about 4k rpm if you notice a drop in the power or it isnt building as fast as it should - one of the pipes isnt connected/tightened properly
exhaust will only play a role if its way too big or too small other then that its just noise if its all stock
I have a Neo in an R32 with a good FMIC and 3" with good cat and dump. Just running off the wastegate with no boost control (didn't install the R34's solenoid) I could not get more than 6 psi. That's from a 5 psi actuator. Engine is in perfect health, etc etc etc, blah blah.
You shouldn't be getting too much boost (if that's your problem) from just an exhaust and FMIC. You might gain a psi or 2, and that might get you up to nearly 10psi, but the engine and ECU should be perfectly happy there.
I get to much boost goes to near 1bar constantly and tyred everything boost leak tested aftermarket controllers I even ported they wastegate hole for the hell of it but still 1bar even of just the wastegate actuator so it shouldn't be over 10psi should it unless something's wrong hey only thing else I could think of is ecu has a malfunction ?
ECU malfunction cannot cause that much boost.
So, you're telling us that you have completely dismantled the whole turbo system trying to fix this problem? So you know that the wastegate is 100% free to move, not jammed in some way? Do you have a dodgy split dump pipe installed? Anything else that we should know about?
Has a split dump pipe but flap moves freely vac lines anit stuffed changed all of them
3times to make sure standard turbo standard wastegate and tyred another rb25 one to
Wastegate opens when I put the compresser to the vac line and don't loose any pressure
It's like the when the car is standard it boost to 5psi then 7psi
But after the mods does .5 bar to 1bar lol
OK, so next test. Disconnect the wastegate actuator rod from the gate lever arm. Tie the lever arm so that it is jammed 100% open. Take for a drive and report back. Expect it to take an age to come on boost, but if you drive it up hill in 3rd at about 100 and give it a bootfull it should come on.
If you have an air compressor feed some air directly to the wastegate and set your compressor to push 5 7 10 12 psi in increments and just check each level of pressure make sure the wastegate actuator is opening correctly. Unless its internally seizing up it should still open at stock levels. Also I doubt your split dump is helping. I had a split dump for about a week. It was overboosting. When I tested my actuator you could hear the flap hitting the dump on the inside. It looks fine before you bolt it on but I found it was my issue.
Yer drove it without the actuator on at all makes no boost till high rpm then just makes a lil
And my wastegate flap don't touch at all opens fully backwards in the split pipe so anit hitting anything and slowly tested it to
And opens fine That's what I mean I've tyred near everything
You can test wg spring using a large plastic syringe with a vac line attached to you wg actuator with a boost gauge t'd in. That will determine actuator psi.
Then check that you wg flap dosnt foul on you dump.
If its still a problem put a bleed tap on the vac line leading to your bov.
Check out autospeed.com.au for more info on that
By contrast though, mine is fine and always has been.
So another words Mine should be ok on the mods
How about the boost sensor ? If that plays up would it do anything not the solinoid the sensor on the back firewall
No. The boost sensor on the firewall (the ECU's sensor, not the gauge sensor) doesn't act until much higher boost levels. For example, when I was first tuning my boost controller (on this Neo engine) I had a problem with the pressure regulator I was using. It was basically jammed shut. So I had zero boost control. I saw 1.2bar a couple of times before working out what the problem was. In lower gears it would do this happily, with no savage boost cut type things going on. But if I tried it in 4th gear, the boost would shoot up there and there'd be a fairly savage cut. Once I got the regulator working properly I tried it a couple of times at nearly 1 bar and there was no savage cut (although I do get some R&R behaviour evident at high loads, that's a separate issue). The message here is that the boost sensor not only isn't used to set your boost level, it isn't actually used for anything very much at all. I have a suspicion that it might play a part in determining whether to fuel off the fuel map or the VE map, but that's a separate issue again.
I broke my boost sensor (accidentally) off. Never noticed a difference ever. Was trying to figure out why for a long time haha.
shouldnt have to if other r34s can run the same mods and not have a problem should just work dam it grrrrrrrrrr
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
