Yeah the back plastics on mine have plenty of cracks.
That's the reason it keeps coming back.
Tried to use silicone to seal up the cracks but it's not working.
I'll have another check this weekend and see what I can do before purchasing them.
Epoxy not silicon :thumbsup:
Okay so the timeline starts again.
So after fixing the radiator, rolling the guards, getting the coilovers installed & putting on the rims.
It was here! NATS! WOOOO FARKEN HOOO KARNTS!
I hadn't slept in days because I was so excited.
Got myself a helmet and loaded up the car with some spares just in case.
Wvyj1Qw.jpg?1
I pulled up at the nats and found myself a little spot next to Mat Geeteetee and unloaded the car.
Met all my whores from whore town who I hadn't met in person.
Who knew Tailor Made was going to have such a homo haircut haha!
Zc9hzxT.jpg?1
Got the car out on the track and had an amazing time! Didn't have any gauges so I took it fairly easily.
1-2 hot laps and then a cool down lap, this worked well for me and the car didn't give me any issues.
I walked away with a 1.26 which was an okay time for the first time ever tracking the car.
dQjCjYl.jpg?1
I participated in the track day and the airport drags.
The airport drags was the best fun I have ever had and I think I got like 10 runs or more.
My best time was a 14 seconds flat I do believe.
y4V8hAu.jpg?1
On the very last run I thought I would give it my all and spent a fair bit on the limited.
Got halfway down the track the battery light came on and the temps shot through the roof.
Popped the bonnet and coolant was everywhere.
After closer inspection I had shredded my fan belt.
Mat was kind enough to go pick me one up and help me change it on the side of the road.
Rob pulled over and had a chat while using his hazards to make sure we didn't get hit
uqJKP6x.jpg?1
This is where I would like to give a shout out to Rob for his amazing effort.
After getting home I found that we had driven off on Rob and he got back in his car and had a flat battery.
He spent a few hours on the side of the road waiting for the NRMA as we boosted off into the distance.
(Rob I still owe you that drink or 10 mate)
yinHyMb.jpg?1
Big thanks to Matt, Carmon & Rob for helping out and keeping company.
I would have been stuck there without you guys.
Ohh and here is a model shot of Josh (Tailor Made) & myself inside the car.
7Ops4as.jpg?1
After the weekend was over I cruised home with old mate Trozzle
bPRthGa.jpg?1
NATS! WOOOO FARKEN HOOO KARNTS! Indeed! :D
Twas my pleasure and in reality, my Battery was only 2 months off Death anyway, so not your fault. :thumbsup:
But I'll still Have those Beers ya flamin mongrel! I'll keep these Winkers for Ransom til you make good. :laugh:
And yeah... Mat - "34GeeTeeTee" Legend. :thumbsup:
So I cleaned my throttle body a few months ago.
Not thinking I actually cleaned off the sealant around the butterfly.
Could this be the cause of high idle?
How would people go about adding the sealant back and what would you use
I did the same thing and my car idles at 2000rpm now. Makes driving slow nice and easy as you don't have to accelerate.
The sealant is some special crap you have to buy if you really want to fix it. I'm pretty sure it's from tomei.
Source of your whistle?
could possibly be
This could be the reason that you only get it on a certain vacuum
Because it is in a certain position that causes the whistle.
Now just to find out what product I can use.
Some say gasket sealant but I don't want it to get sucked into my engine.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
