Back to the story.
After finishing up at nats and having a mad time things went back to normal.
Just the usual things started with the car.
Removed my turbo timer and came across this mess.
Not sure who the hell did this home job but it all got removed and fixed.
lDHYqLh.jpg?1
After a few spirited runs through the cotter I noticed that my intake gasket was shot.
So I ordered a new one online and did some research on how to change it.
At the same time I decided to get rid of the hicas and chuck a lock bar in it.
The intake gasket is a farking bitch to change! cut the fark out of my knuckles, lost a spanner (still haven't found it lol)
If you ever have to change one then make sure you have ratchet spanners because they are awesome!
4pHq5jS.jpg?1
Well it only took me a week to do :P but Yeh, it's very tidy and works much better than it used too. Hopefully yours does too! Good job on pulling out the turbo timer too, I'm glad to be rid of mine. Should have listened to everyone that told me when I put it in, but I was all excited about having a turbo car :laugh:
Haha that's exactly what I was looking forward to when I purchased the car. Felt like a sick karnt walking away from the car while it idled for a while.
The novelty wore off within a few months and I couldn't turn the damn thing off otherwise the car wouldn't start. Home job wiring
Yehhh, mine stopped working. Wouldn't keep the engine running, but kept the electrics on for 30 seconds. Means my oil pressure gauge would scream at me when I shut the engine down at the pressure dropped below 20psi :laugh: So far no sign of my old starting issues either, so I'm hoping they were related to the turbo timer.
ANYWAY, got round to doing the throttle sealant yet?
It's been one day dude haha
Throttle body sealant will be done this weekend I hope.
I'm going to use some glue that I have here and make sure it's a really fine film so that it breaks when I open the throttle.
I will report back how this goes.
The proper sealant can be purchased but its $80 for a small tin
Fark that
Make sure that glue is oil resistant, you don't want blow-by breaking down the glue and having it fly into your motor :/ Personally I'd fork out for the correct stuff, $80 is cheaper than causing other problems...
Communal goo? - sounds like soggy SAO game !
but Robs onto something. I think there would be a number of locals who might need/use
or perhaps a shop like Trojan might part with enough to help you out.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
