Bryce it's only used for sealing the actual butterfly inside the throttle body.
IF you haven't cleaned the stock stuff off then you have nothing to worry about.
You would think the workshops around here would have something they use.
I texted my mate at Toyota and he is going to check for me.
If I can't find anything then I might just bite the bullet and order some of the stuff.
Check this stuff out guys
http://www.permatex.com/products/product-categories/gasketing/gasket-sealants/permatex-form-a-gasket-no-2-sealant-detail
"Slow-drying, non-hardening brush-top sealant approved for use in aviation as well as automotive applications. Temperature range -65°F to 400°F (-54°C to 204°C); resists gasoline, oil and grease. - See more at: http://www.permatex.com/products/product-categories/gasketing/gasket-sealants/permatex-form-a-gasket-no-2-sealant"
Suggested Applications: Valve cover gaskets, oil pan gaskets
kasko you should try some Hylomar, was recommended to me by scotty for sealing off my plenum and its worked so far, so for your throttle body it would be worth the $14 to try.. comes in a bottle or spray
Started up the car on Monday and it had a rough idle.
Gave it a little rev and it stalled.
Been trying to diagnose the issue for the past 2 nights.
After checking fuel & spark I finally got to checking comp
GAME OVER
Cyl 1 = 90
Cyl 2 = 25
Cyl 3 = 70
Cyl 4 = 90
Cyl 5 = 60
Cyl 6 = 70
Haven't done it at all
Owned the car for 45,000km
And I'm not sure when the previous guy did it.
I guess I should have checked it and done it when I first purchased the car. As you know I have had both power steering and fan belt snap.
Yep i recall :P
Maybe check the timing and condition on it first by just taking the top cover off....
The fact all cylinders are down indicates something dodgy going on...
Everyone seems to think the engine could still possibly be okay. I always fear the worst in these situations.
I'll take the cover off tonight if its easy enough to get to. Should only be a few bolts right?
Yeah its easy enough man!
And at the end of the day, who cares if its the engine? Its a standard RB, its not the end of the world :) Look at the positives hehe
Not worried about the cost of a new engine.
More worried about the labour costs to pull out and fit a new engine.
You have mates local, beers + Sausage fest and itll get done!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
