Hi,
I have built a laptime database web platform. Basically its the 'laptimes thread' but made into a dynamic website that no longer requires someone to update it. Simply, make an account, do a time then enter the details along with the natsoft or equivalent official link and it will be instantly represented (subject to my checking the link), allowing you to see your place.
I have featured every main Au racetrack (if you want a track added just let me know) and you are able to search laptimes based on track, car make and model, street rego or not etc.
hopefully this provides a quick and easy way to keep track of where you sit in the overall scheme of things.
http://www.laprecords.com.au
Check it out, let me know if you see any problems/issues or have recommendations. Enter your times! Its free
Thanks.
https://www.sau.com.au/forums/topic/429669-wwwlaprecordscomau/
Nice work, great idea.
- I think it would look nicer if it was maybe 25% wider ?
- Should the same person be able to enter multiple lap times for the same car? I know some people that would have 100 laps that are faster than the current quickest for tracks that could flood the entire records.
Thanks. You can enter multiple times in the same car however if you're just filling up the leaderboard with 1:01.1, 1:01.2, 1:01.3 etc then i'll just remove them. Upload your best time and if you beat it and upload to the same track again, it will remove your previous time if it was in the same car. The idea is that each person is represented once per track, per car. If you have 2 cars then you have more money than me :)
Yeh mate, running on a NAS server in my house. Simple but seems to work ok. I'll migrate it to something more serious if it catches on.
A link in with natsoft is probably the way to go, but not sure where to start with that. Call it a long term goal. :)
  • 2 years later...
  • 5 months later...
  • PranK unpinned this topic
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
