Hi,
I have built a laptime database web platform. Basically its the 'laptimes thread' but made into a dynamic website that no longer requires someone to update it. Simply, make an account, do a time then enter the details along with the natsoft or equivalent official link and it will be instantly represented (subject to my checking the link), allowing you to see your place.
I have featured every main Au racetrack (if you want a track added just let me know) and you are able to search laptimes based on track, car make and model, street rego or not etc.
hopefully this provides a quick and easy way to keep track of where you sit in the overall scheme of things.
http://www.laprecords.com.au
Check it out, let me know if you see any problems/issues or have recommendations. Enter your times! Its free
Thanks.
https://www.sau.com.au/forums/topic/429669-wwwlaprecordscomau/
Nice work, great idea.
- I think it would look nicer if it was maybe 25% wider ?
- Should the same person be able to enter multiple lap times for the same car? I know some people that would have 100 laps that are faster than the current quickest for tracks that could flood the entire records.
Thanks. You can enter multiple times in the same car however if you're just filling up the leaderboard with 1:01.1, 1:01.2, 1:01.3 etc then i'll just remove them. Upload your best time and if you beat it and upload to the same track again, it will remove your previous time if it was in the same car. The idea is that each person is represented once per track, per car. If you have 2 cars then you have more money than me :)
Yeh mate, running on a NAS server in my house. Simple but seems to work ok. I'll migrate it to something more serious if it catches on.
A link in with natsoft is probably the way to go, but not sure where to start with that. Call it a long term goal. :)
  • 2 years later...
  • 5 months later...
  • PranK unpinned this topic
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
    • Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
    • Yeah good point, it won't flash on indicator that way, so plan B, just another wire to run from under the dash which makes it a bigger job 30 to indicator + globe side 86 tapped into 12v input to flasher relay under the dash (has 12v when indicators on, nothing when no indicators) 87a to headlight parker + 87 to original indicator + chassis side 85 to chassis/earth Now it will flash with indicators and be solid on with parkers
