This has been a constant issue since I've had the car but it has never failed me to date.
Generally it take about 3-4 seconds of cranking over before my car starts no matter if its hot or cold. But sometimes it will start straight away, rarely.
My tuner told me this is common for some cars with aftermarket ECU's. My father thinks it could be the advanced timing and rich on start up but I'm unsure.
My ECU is a Wolf 3D V4 running a MAP sensor and fuel pump is an 044 and running Nismo 740cc injectors.
Feedback would be appreciated. As I stated the car hasn't actually ever failed to start.
Cheers
https://www.sau.com.au/forums/topic/429678-r33-starting-issue/
Do you prime the fuel lines before starting? as in, turn the key til the fuel pump does it's thing and stops and then turn it further to start?
I installed an 044 intank and it has No non return valve so when the car sits for a while, the fuel seeps back into the tank.
If I try to start it straight away, yes, it takes 3 to 4 seconds to start but if I prime the lines, it starts right up, cold or warm.
This rarely happened with my stock pump but it didn't seem to have a valve on it either.
I just recently bought a non return valve to try stop this and will slap it in soon.
i also think bigger injectors take a bit longer to kick over not sure though.
nah. I have id725 injectors with nistune and car starts instantly. I also had a wolf 3d v4 10 years ago. It is an old computer....
that's crap, did you read this from some honda forum? :)
OP, are you running E85? in the cold it's a little bit of btch to start..
I generally let it prime up for a few seconds then turn it over.
Just running 98 octane.
Thanks for the replies fellas
find a new tuner, seems he hasn't set the cranking enrichment table properly :)
Mine does the same thing, it even ran today for a few seconds then cut out. Once restarted it is fine, although very doughy for the first 20 seconds or so. It's just so much ethanol getting injected and not enough petrol to fire the mix.
I am seriously thinking a dual fuel setup with petrol running off the stock ecu/injectors perhaps, and e85 on secondary injectors is the way to go, for economy, higher K's to the tank and improved starting in winter.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
