I just had a Nismo GT Pro 1.5 way put in a couple days ago - and I can report that it shits all over the crappy viscous LSD I had. Tight turns (especially when cold) are a bit 'surgy/skippy' but it settles down when warm. No real clunks, and it's made a big difference to acceleration - even though it still lets go (e85 - 300rwkw) the car still accelerates through the wheelspin, instead of just breaking sideways or spinning one tyre to redline in a flash.
Very impressed so far.
  • Like 2
didn't I tell you that from day one? haha...
good stuff bro!
you still need to take me for a spin soon!
coming to skids on 7th Oct?
Yeah pretty much hey! Don't know it until you feel it I guess.
Msg me the details of the skids!
  • 1 year later...
So since i am RWD and have never been in a car with a shimmed R33 GTR diff, if done well do we really expect it to get out performed by a Nismo 1.5 GT Pro. Its worth the extra money to me if traction is going to be better but...would a shimmed R33 diff be as good as the Kaaz 1.5 way I am running now?
Good question, I had a spare R32 GTR diff rebuilt and tightened and put into my 34, I took car out Friday in RWD due to sensor issue and full noise in 2nd at 19psi ( was going to try 22psi but thought better of it ) it hooked up and took off with no wheel spin, on 275/35/19 Hankook RS-3s
It use to fry one back tyre till the 4WD kicked in then take off, has LSD up front
Exactly Paul - didn't see oil mentioned anywhere... Oil plays a massive factor.
I used the Castrol and my GT Pro (1.5) from the start, would still lock in a carpark @ low speed on the lowest setting with some accelerator, but I didn't mind it at all.
Could simply add some Penrite Friction Modifier if I wanted it to be more forgiving. Very much a personal preference type of thing the ole rear diff lock-up.
That said I've had shimmed R200 and a Nismo in a R200 - Nismo is certainly awesome, but take nothing away from a properly shimmed mechanical R200, they do very well for the amount of outlay.
How much of said modifier and is it a "permanent" thing - ie if it is too much does draining and refilling it with unmodified oil return it or is in in the plates for a while?
Get a front on photo of the whole in the centre - will tell show more if its a 2way or 1.5 etc.
Just an update, got my Nismo 2way detuned by a place here in Sydney- apparently reduces the harshness but maintains lock to improve drivability, and got some good oil put in.
Popped it back into the car and cannot stress how great it drives. Gives the odd clunk when cold but once it gets some oil through it drives as nice as a viscous LSD but with instant 2 wheel action as soon as the clutch drops.
Also gives the odd chirp on car park concrete which is no issue at all.
No shimmed LSD no matter how good (i thought) it was, was even anything close to as good as this.
Highly recommended � I'm wrapped
Who are these mysterious people?
Edited by djr81
The friction modified is just an oil additive, so oil change (or more likely two) should just flush it out
And yeah the Nismo GT-Pro has settings, you can back them up or down depending on what you want.
If not a Pro, it'll just be a case of altering the diff plates
  • Like 1
Hi Paul, I sent you some old worksheets ages ago that I got with the car yard when I bought it, one of the work sheets was from Advan Performance Auburn and they had installed a Nismo 2-way LSD , but after reading a lot of threads about LSDs I questioned that this could be a 2-way as I get no noises or clunks at any time.??
Got CRD to have a look while the car is in bits and he said he could not tell what brand it was but it was a strong one, whatever that means?
Even before when the car would not get going it used to chirp at near idol revs, I thought it was the OS Quad clutch doing this, the chirps stopped by the time I ran the car in.
It will be interesting to see what happens once I get it back with the other drive-train mods installed
The problem with shimmed V-LSD is that they wear and need re-shimming. Even at their best they still aren't a proper LSD. I have a Nismo Pro 2 way set on the lowest preload. It's great, especially in the wet, very predictable. I was very lucky and got mine for $500
Nobody said anything about a VLSD.
  • 4 weeks later...
  • 3 months later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
