Hello
if someone out there run this:
Skyline r33 gtst RB25.
injectors around 700cc.
more thing like, bigger turbo, plenum intake....
If you use Haltech platinum Pro box so please send me your map.
I need a pretty good map to tune wiith.
Emiiilz :)
https://www.sau.com.au/forums/topic/429697-haltech-platinum-pro-send-me-a-map/
Trust me you dont want to do this. Around 700cc injectors. If they are running 700cc injectors what if their latency is different and other variables? What if their turbo comes later than yours, you can pop your engine if the timing is too high. If you have a wideband go do a quick tune your self. Set the taget afrs let the car auto tune the afr for you and just use some safe timing. Doesnt seem you know anything about the mods in your car. Dont risk killing your car. It will cost you more than a tune to fix.
Im also looking for this. I have just done some upgrades and have been advised not to drive it to get tuned and to trailer it. I would rather load a mapping so that i can drive it down to get tuned.
I have an RB25DET NEO (R34 GTT) with following mods:
* FMIC
* Haltech PS2000
* Pod Filter
* EV14 Bosch 725cc top feed injectors
* Walbro 455LPH
* FPR1200
* TurboSmart BOV
* Stock Turbo
* eBoost Street (boost to 10 PSI low and 12 High)
All you have to do is set your injectors and granny drive to the tuner. You dont need and do not want someone elses tune. You have all the software. Get a usb out there and find the injector settings off the site or google or from the manufacturer.
Also why the decent mods on a stock turbo? If you are going bigger later you'll be paying for two tunes.
Edited by SargeRX8
yeah, im going to get a GTX3076R vband.. just havent made it there yet haha. Yeah aware of double tuning, not much i can do about it atm.. I have 0 knowledge for using the software, pretty easy to change the settings for the injectors? really just wanna be able to get it down for the tuning. OR maybe find someone local who has a trailer i can borrow/hire just hard caz its lowered :P
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
