So a 355mm rotor is half the story. You need to make up your mind over the brand and check the hat offset. Manufacturers use different height hats and different thickness hats...all offseting the rotor differently that means you need a bracket to offset the caliper appropriately.
If you dont have rotors than the link DJ posted is a good option. great quality rotors and hats and can buy the brackets off them.
If this helps it is a drawing of an adaptor bracket for an F40 to R33 GTR rotor (324mm from memory). If you have the offset of the 355 rotor (What Troy was talking about) it is easy enough to figure out the measurements for the bracketry required. The one I ended up with is pretty elaborate and most are much more straight forward. Anyway the trick is to find someone who will machine it for you at a reasonable price.
bracket.PDF
As iam looking for brakes for my R32 GTR as well ive come across these if this helps
www.ao-ps.com
heaps of different rotors available and brake pads.
Giro Disc
Project Mu
A few people have spoke of trying it but unless you have ABS I say it will end up a bit of a nightmare as the EVO brakes use a piston size as big./bigger than FPV Fords which is waaaay bigger than anything Nissan ever intended for this cars.
  • 1 month later...
attachicon.gifbracket.PDF
+1 Finding someone who will machine at reasonable price and making sure the rotor offset is correct - unless anyone has access to a garage who can do both for you, can be tricky
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
