1986 build Japanese market Trueno.
225,xxx.
$10,000.
Owned since 2007. Purchased whilst I lived in Japan. Modifications have been done in order to improve but not detract from the spirit of the car. It was bought with stock suspension and engine so I assume it hadn't been tracked, and I haven’t tracked it. It’s only been driven as a reliable daily. Exterior and interior in good condition for a 27 year old car. AE111 Blacktop conversion at 19,5xxx. Before installation, all engine seals were replaced, head was ported and valves reseated, new water and oil pump and a new radiator was fitted. Running stock ECU for factory reliability. Suspension was also upgraded at 19,5xxx. Front coilovers with Swift springs front and rear, TRD front sway bar and all bushes replaced. Complied and registered as a two seater. In the rear seat well a false floor houses the battery, sub and speaker amps and an 8in Alpine Type R sub in a custom fibreglass box. It had air conditioning but the compressor was removed to fit the Trust oil cooler. The condenser and pipes are still in the car and I have the compressor, so if one wished the air conditioning can be refitted.
Bits and pieces;
Trust exhaust manifold
HKS catalytic converter
Trust oil cooler
Front coilovers
TRD front swaybar
Cusco camber tops
2 way LSD of unknown brand
Steering rack spacer
Hayashi and Longchamps, both 14x8 with negative offset
Carbon Fibre bonnet
One piece alloy rear strut brace (not shown in pictures)
R32GTR seats
Nardi steering wheel
TRD gear knob
Defi tachometer
Pioneer CD player with iPhone and USB capability
2x Sony amps
Alpine Type R sub and speakers
It still had the factory Apex wheel arch molds when I bought it. I haven’t had the time to fill and paint the holes left by their removal. There is a small amount of rust in the left rear wheel arch. The front bar has significant stone chips and is in need of repainting. Dash has the inevitable crack. Air conditioning control fascia has a hole in it.
The car will not be sold with a roadworthy certificate.
Registered in SA. Car currently with me in Townsville, QLD. Can show the car in more detail on Skype for interstate buyers.
I am happy to organise shipping to anywhere within Australia.
Mob: 0435 281 536
Have a look at my parts for sale post (when I get around to writing it) for things like rear hatch spoiler, original door cards, rear seats and carpet, Defi gauges, parts to get the air conditioning working, original 16v engine, original suspension, original power steering rack, etc.
th_DSC_0037_1.jpgth_DSC_0033_1-1.jpgth_DSC_0027_1.jpgth_DSC_0024_1-1.jpgth_DSC_0018_1.jpgth_DSC_0014_1-1.jpgth_DSC_0008_1.jpgth_DSC_0007_1-1.jpgth_DSC_0060-1.jpgth_P1070387_1.jpgth_P1070389_1-1.jpgth_P107039711_1-1.jpgth_P1070393_1.jpg
Edited by dodgybrooks
https://www.sau.com.au/forums/topic/429711-jdm-ae86-panda-trueno/
Since posting this ad in two days I've been inundated with inquiries, which leads me to the conclusion that the initial price I put on the car was not what it was worth. I don't want to rip anyone off, but more so I don't want to short change myself so the price has been changed to $13,000.
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
