All parts located in A.C.T
Will post AUS wide.
-R33 nismo side winkers used $50 posted
-Nismo leather wrapped gear nob test fitted brand new $60 posted
-R33 S2 drivers head light all tabs intact, average condition, cloudy around indicator $80 posted
-Advantek wheels 17 x 8 +38 5x114.3 average condition, wheels gutter rashed but no dent or cracks, will clear brakes on all skylines, silvias besides gtr.
Front tires 3months old rear tires 8months old. 235/45 all round.
$700 posted
All prices cheaper for local pick up
PM for more details.
Cheers
Patrick
Edited by Pattey21
https://www.sau.com.au/forums/topic/429714-r33-parts-and-17-wheels-for-sale/
  • 1 month later...
Update all part prices not including postage
-Genuine nissan engine and gearbox mounts all in excellent condition $50 per mount
-Bridgestone potenza street suspension; shocks and springs all round. No leaks or knocks and rides better than my new bc coilovers.$300
-stock castor rods newish bushes $40
-stock rear upper camber arms $30 pair
-stock r33 shifter good new bush $50
-superpro subframe bushes, new bag $30
-nismo leather wrapped gearnob still new in box $50
All parts located in canberra happy to ship as cheap as possible.
PM for more details
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
