Pretty keen for this - does anyone know an average price for a wakie day?
My last pay day is next fortnight - need to see if it's in budget.
$150 for day
$50 for liecense
$80 fuel to get there
$40 top up
$80? for a tank at lunch?
$40 top up for ride home
$10-20lunch
$40 oils
Total: $490 - sounds about right?
Edited by RosieR34
$150 for day
$50 for liecense
$40 top up
$10-20lunch
$40 oils
i used about 80litres total for the day you use a half tank getting to goulborn and back so petrol cost is about $130
buy a 1L bottle of oil $15
so about $410.
  • Like 1
It is not totally unlikely that your car will break, I had mine trailered back once, at a 350$ cost. Due to a bad driveline noise. (turned out to be a loose pully.) But it's not totally impossible, you are stressing the car and pushing it, so it's not impossible that a turbo could blow, or you have some kind of failure.
My advice apart from what everyone else said, is do some slow cooldown laps as well, dont flog the car the entire session. I was doing a fair few hot laps and would then do a slower lap to give the car a break.
$150 for day
$50 for liecense
$40 top up
$10-20lunch
$40 oils
Also budget for a potential set of new tires, unless you have slicks or semi slicks, you will put a bit of wear on your tires.
you determine how hard you push your car. you dont need to go all out and non stop.
if your car is on its last legs for tyres or brakes etc or already has issues on a daily driver level, then sure best to give it a miss.
same deal if your pushing it financially but otherwise lets not get too pedantic.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
