Pretty keen for this - does anyone know an average price for a wakie day?
My last pay day is next fortnight - need to see if it's in budget.
$150 for day
$50 for liecense
$80 fuel to get there
$40 top up
$80? for a tank at lunch?
$40 top up for ride home
$10-20lunch
$40 oils
Total: $490 - sounds about right?
Edited by RosieR34
$150 for day
$50 for liecense
$40 top up
$10-20lunch
$40 oils
i used about 80litres total for the day you use a half tank getting to goulborn and back so petrol cost is about $130
buy a 1L bottle of oil $15
so about $410.
  • Like 1
It is not totally unlikely that your car will break, I had mine trailered back once, at a 350$ cost. Due to a bad driveline noise. (turned out to be a loose pully.) But it's not totally impossible, you are stressing the car and pushing it, so it's not impossible that a turbo could blow, or you have some kind of failure.
My advice apart from what everyone else said, is do some slow cooldown laps as well, dont flog the car the entire session. I was doing a fair few hot laps and would then do a slower lap to give the car a break.
$150 for day
$50 for liecense
$40 top up
$10-20lunch
$40 oils
Also budget for a potential set of new tires, unless you have slicks or semi slicks, you will put a bit of wear on your tires.
you determine how hard you push your car. you dont need to go all out and non stop.
if your car is on its last legs for tyres or brakes etc or already has issues on a daily driver level, then sure best to give it a miss.
same deal if your pushing it financially but otherwise lets not get too pedantic.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
