Maad.
Still coming along Pattey?
Don't know att his stage depends how much i get paid. Had my wallet stolen last weekend at Vans Warped tour which was expensive. It also had my ASAA or whatever card in it too :(
Ahh that sucks.. Worst nightmare right there :/
dads paying for it, but said he cant take me, mum will NOT take me ( hates motorsports ) im working on dad..
count me in as a maybe.. ill sure be up for the cruse, ( cant exceed the speed limit :( ) because I dont know the way :P
where is maccas near exhibition park? you go past exhibition park going from civic to Mitchel yea?
Last maccas before you leave Canberra heading towards Sydney
thanks, I cant go, dad wont go in my car until it proves it self ( it was written off and I fixed it... must no believe in my skills )
have a good time guys! ill try and convince mum, very unlikely tho :(
So.....
Boiled my brake fluid, shoulda changed that before i went.
Lost half of my engine oil, dunno where it went, it happened during laps. Should have taken more spare oil.
Got some more from town, and noticed my diff was extra noisy, left shaft clunks badly, the one that Toll Ipec smashed and never paid for (fck you Toll Ipec). Back at the track, i looked and saw diff oil all over the diff. Front seal leaking.
Time to call it a day before i break something.
Rob said; roughly 1:22, for one of my laps.
Next time ill be better prepared.
And ill try those Remsa pads too, they might not smoke like my Bendix pads.
Ps: the Skywagon is a good support vehicle. thanks again Rob.
What a mad day! Where to begin... Thanks to Mik for organising it. Shame your car started having issues :( Was great having Rob along aswell. As I said before, I think it's more enjoyable with a mate there. The driving was so great, awesome value for money. Pb according to racechrono was 1:17 flat, though I only used racechrono for one session. Needless to say I'll definitely be doing that again! :woot:
nice work! Shame I couldn't come. What tire were you running?
Could be a suspension thing. Coilovers on the rear? Possibly too stiff?
Theres heaps of grip on the track, unless you go into a corner too hot you have to be trying to get sideways for it to get out of control. For me anyway, im still running fairly stock :)
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
