Good to see you all had fun :) and didnt damage anything (too badly)
Im thinking of doing a SOTS day in late january/early feb if anyone wants to go again.
keep us updated. I'd love to go back again :)
Dates for Jan-Feb:
Jan
Friday 10th
Mon 13, 14, 15, 16, 17.
tue 23
sat 25
Wed 29, 30.
Feb
tue 4
mon 10
20, 27 are thursdays.
How's Thursday 23rd? Or the 25th?
Actually I need to check work roster before I can commit to a weekend
Edited by dontyellpl0x
LOL! you sure are Big Boy. ;)
If before the 20th of January any day is good. If after the 20th, weekend.
(but I'm only a spectator so do whatever yous wants aye Cuz.) :D
Haha ok. James have you decided which day you plan on going?Maybe Wed 15th. Middle of the week, might be quiet?
Edit.
I wont be able to make the 15th, maybe the 17th or the week after. I normally go mid week as theres less people on the track
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
