Also Newbi!
SouthernR33
 Share
Hey all,
Can't say i've been on a cruise and can't say that i have any mates who care about imports but i've been modding my 95 R33 GTSt, you may have seen it down south, it's white with a carbon fibre bonnet. I'm pretty keen to go crusing with other like minded folk. I'll be checking up on the forums and hopefully catch up on the next cruse.
Cheers to all. :D
yes that was i "ricing" it up at yumsing.
Cheers patto & Miss_Nismo.
Must be a night for racng. Just embarrased a VN on the way home from marion only for a second VN to wanna give it a go. I had to decline though. His VN was in very bad condition and i didn't wanna lower my cars standard. (yes i'm a smart arse, but i own a Skyline so it's ok)
I'm down at Port Noarlunga Sth WILLZI and i must say that crusin the strets down here you get alot of attention as imports are not as common.
i may have seen your yellow 33 not sure.
Cheers to all and VERY nice ride CheekyR32.
Why thank you kind sir....
 Share
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
    • So I've got my R34 GTT it's currently in Japan and I'm not there. I was wondering if any has any tips or ideas of what could be preventing the door from opening. I dont have really any information on it at all since I haven't actually seen the car in person yet.
