Really? That's one of the best thought out responses you are likely to get.
yeah man, I tend to have this thing where I kind of understand but don't, so need someone telling me a solid yes or no.
but other than that, got complete rb25det ready to be mashed up with the rb30 :P
What I meant was using an RB25 Neo turbo head and it's inlet manifold .
It's not an easy job grafting a RB26 inlet system onto any RB25 head and if driving conservatively much of the time I don't know why you'd bother . To me there is only two reasons anyone would ever go with an RB26 head and they are the shim under bucket lash system and the six throttle inlet manifold . The aims being valve train reliability at very high revs and sharp throttle response . Big revs is not a consideration for normal road driving and single throttle inlet systems work fine in these applications .
So basically yes I think an RB30DET based on the Neo turbo head would be easier to get better consumption from - particularly if you can get the static CR around 9.5 to 1 and run it on something better tan basic E10 or 91ULP fuel .
I'd also consider using a taller diff ratio like say 3.7 or 3.9 because doing close to 3000 revs at 110 km/h won't help consumption . A 20% larger engine can in theory pull 20% taller gearing which works out to be around a 3.29 diff ratio , not hard to see how that's a bit extreme so if you halved that to 10% it works out to be a 3.7 final drive ratio . Lighter VL Commodores with RB30Es (SOHC 9.5 CR) from memory had a 3.45 ratio final drive and something very similar to an RB20DET gearbox inc ratios .
A .
Edited by discopotato03
A .
thanks mate. my goal is to just gain more rwkw and better response in comparison to my NA RB25DE Neo without compromising fuel economy . no need for high revs as I've never gone over 5k rpm anyway.
A .
your memory must be failing you :-) rb30e sohc had 9:0 to 1 cr , not 9:5 to 1 due to cats piss 88 octane available at the time Edited by StevenCJR31
Yes well memory fades and yes we did start out with urea grade ULP .
Anyway torque is king IMO and getting it in a reasonably free spinning package can only be good . I hear people say that in basic terms the difference between an RB25 and an RB30 with the same lid/CR is about 500 revs . I think at the end of the day the head and manifolds have a large say in the total power potential and the capacity dictates at what engine speed you reach the top ends limits .
Obviously more cubes means more torque at the same revs or same torque at ~ 20% less revs than a 25 .
If you soft pedal most places with small throttle openings and lowish revs then the 30 is good because it will pull higher gears down there more easily than a 25 .
If you give it taller gearing , final drive , you will get a bit more speed in the gears and make the best of the extra low down torque . Life would be good cruising down the Hume at 110 doing 2500 revs and never having to change down . If you sized your turbo so its not trying to boost at these revs every time you touch the loud pedal and tune the engine properly it should get good consumption .
A .
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
