I have to clear out some space in the garage after the rebuild.
so i have for sale:
Clevite 77 sr20 rod bearings brand new STD size 1 & 1/2 sets (you need to buy 2 sets to get enough for a rb so i got 3) $55
RB25det head/intake manifold/injectors/fuel rail/exhuast manifold/Throttle body
Getting cleaned and checked now also getting a reco (valve seats cut, milled & crack tested)
- $900
Rb25det s2(I think) manual computer
-$100
RB25det AFM
-$130
Rb25det Block, crank & rods good condition stock bore (with oil pump & crank pullys)
-$400
used stock rb25det pistons that look ok (comes with the rings if you like)
-$25 each
Rb20det head good condition just head & valve gear
-$400
Gold Coast/bris buyers would be nice but i dont really mind sending the small stuff
E-mail me for pics if your interested.
E-mail: [email protected]
Thanks
John
https://www.sau.com.au/forums/topic/42976-eoi-rb25det-parts/
can you give the engine vin these bits came from or what year it was?
i have a series II rb25det and could be interested in ecu and afm but want to be sure its a series II, 1996 to 1998
https://www.sau.com.au/forums/topic/42976-eoi-rb25det-parts/#findComment-919392
paul sorry but i cant supply the vin because i bought this engine from a workshop in bits as i needed some for my engine. Also there where differances in sensors and idle control on this engine that looked newer then mine.
Part numbers are in the pics below if you can read them. I'll write them out if you cant make them out. (sorry about the quality of the pics i'm trying to get my hands on a digital camera that works should have one tomorrow)
Wilso
I have almost a rb25 long motor in parts but missing
-Crank angle sensor
-oil filter block (stock oil cooler heat exhanger) & cooler
-pistons
-turbo
-temp sensor
Say $1200 for the lot and you can have the big end bearings too or if your just after some parts e-mail me please.
But I have no idea how much it would cost to send the engine overseas.
Sorry i'm using the box
Thanks
John
https://www.sau.com.au/forums/topic/42976-eoi-rb25det-parts/#findComment-919710
express post bags are like $8-9 last time i got one so i'll just throw it in one of those or can send reg post if you would like insurance.
John
so do you pretty much have a complete RB25 there?
i have an R32, and am in need of a new engine. thinking of going to an RB25 but dont really know whats involved...
https://www.sau.com.au/forums/topic/42976-eoi-rb25det-parts/#findComment-927875
so i have for sale:
-$100
RB25det AFM
-$130
Thanks
John
Hi John
I am interested in the ECU and AFM for a project I am doing. They don't have to work.
I am offering $100 for the both plus postage to Melb COD.
Let me know
Cheers
Rob
https://www.sau.com.au/forums/topic/42976-eoi-rb25det-parts/#findComment-927883
I dont really think it would be all that hard to put a rb25 in a 32 (i have one in my HR31) but you would need to talk to some people that have done it before.
As for my motor it would need to be rebuilt with new pistons & bearings before it could ever run not to mention that it is missing a few sensors coil packs etc
unless your getting a aftermarket computer i would get a halfcut for all the little bits you will need. This engine would be good for someone thats already got a rb25 on the way out and needs to get something ready to put in.
Thanks
John
https://www.sau.com.au/forums/topic/42976-eoi-rb25det-parts/#findComment-928030
Thanks
John
I plan on buying a Microtech at the same time as changing my motor.
and considering i will start with $5k, that leaves me with 3.5k for an RB25. but i really wouldnt mind having some left over. just dont really want to stay with RB20.
https://www.sau.com.au/forums/topic/42976-eoi-rb25det-parts/#findComment-928178
Well that is something that you need to think about before you can go ahead, is if you can complete this engine within your budget.
The head was worked over for a bit of a reco/cleanup by my engine builder and The block is in good condition std bore etc. As the machinist is a friend of mine i could see how much it is to get some of the parts preped for you if you like.
Just to give you a quick idea i'm currently rebuilding my rb25 with
aries forged pistons ($1250)
clevite bearings see above ($70)
nissan full gasket kit ($375)
main bearings are still up in the air but they are cheap
plus lots of other goodies that you dont really need but the little things add up.
Depending on how much it costs you to get labour/machining done you may be able to get it done if your a heavy D.i.y'er (like me :D ) if not the labour involved will blow the budget to hell :Bang: i would think
Thanks
John
https://www.sau.com.au/forums/topic/42976-eoi-rb25det-parts/#findComment-928240
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
