Just wanted to check with members here, what coolant temperature are people seeing when idling in traffic with AC ON on a 25-30 degree day?
I know that rb25det neos run a hotter thermostat, so wanted to see what temps people are seeing when idling for a while with AC on?
Also what is the vacuum gauge showing in terms of inhg, is around -16 inhg ok when idling with AC on?
Any replies to clear these up are appreciated.
Cheers
Edited by Bugzs15
There's not much point in asking about the vacumm because it will vary depending on what everyones ECU is doing at that point. Fuel and timing will change the idle vacumm. Mods may also play a part
If your asking this to see if you have a leak then you'd be better off trying to pressurize the system with the engine off
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
