Just wanted to check with members here, what coolant temperature are people seeing when idling in traffic with AC ON on a 25-30 degree day?
I know that rb25det neos run a hotter thermostat, so wanted to see what temps people are seeing when idling for a while with AC on?
Also what is the vacuum gauge showing in terms of inhg, is around -16 inhg ok when idling with AC on?
Any replies to clear these up are appreciated.
Cheers
Edited by Bugzs15
There's not much point in asking about the vacumm because it will vary depending on what everyones ECU is doing at that point. Fuel and timing will change the idle vacumm. Mods may also play a part
If your asking this to see if you have a leak then you'd be better off trying to pressurize the system with the engine off
