August Monthly Meet - Wednesday 14Th August - Kebab Joint
Sunkist
 Share
Kebab joint. A nice place on a cold night.
This month we are having our meet at Kebab Joint - Im yet to find a better kebab, and I've been around.
When: 14th august 2013
Where: Kebab Joint
Corner Springvale Road and Princes Hwy Mulgrave
maps
Time: 7 PM onward
This is an Open event you do not need to be a member to attend this every-one is welcome.
We ask that attendees obey all Road rules.
we don't want people racing up and down the street or general Hooning.
remember you are representing the club
Here is the Menu's to get your mouth watering!
526139_10151199484089973_1434468779_n.jp
There is plenty of Parking too
See you all there!
  • Replies 148
que?
im in and im bring my f**king hsv. lets see how many of you have the balls to gob off in person hahahahahahahahaha!
i kid. will be good to put some names to faces.
Edited by Plattsy
aaron might have to see if scotty is heading up, might have to head to us and follow him up. f**ked if im going an hour south from hallam to sit in my house for ten mins before driving back north again!
This time, stay around for longer for a photo of your Toyota 86.
Haha!
Had movie to attend, friend. I will surely stick around for sexy photo time.
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
