August Monthly Meet - Wednesday 14Th August - Kebab Joint
  • Replies 148
aaron might have to see if scotty is heading up, might have to head to us and follow him up. f**ked if im going an hour south from hallam to sit in my house for ten mins before driving back north again!
Scott will come.. Even when he says he's not, he still does.
Bounce is fkn tiring lol I'll be surprised if you end up coming. Landed on one of the railings there and couldn't breathe properly for about 6 hours. Gooduck lol
No mon, just busy rollin. :P
hahah! i knew youd pop up eventually! you gonna go? i need something to do for an hour after work.... can i hang around your shed like a weird welding groupie?
Lol that's what I do. In addition to lighting fires in his shed as well, which is always fun
you light one ill put it out.... pre meet at scottys? hahahahahahahahaahahahaha.
You aren't gunna get in my pants that easy big boy... :P
Ok, perhaps you will. ;)
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
