Hey ya'll, I've got a series 2 R33 Skyline Gts-t here in Sydney for wrecking. The car was running great with approx 168,00km on the clock, and only had some light suspension arm damage/guttered wheels at the rear, and some faded paint on the roof
Send me a PM or reply here if you're after anything here or any other random small parts. I'm located in Sydney for pickup or I can send most parts anywhere in Aus
Few more pics will be up during the week !
It had a few after market parts:
RPM / PBR Cushioned button clutch, pressure plate & recently machined flywheel, great condition, lots of meat left - $300
3" Kakimoto stainless steel catback exhaust, sensational condition - $300 pickup only
Front castor rods with near new urethane bushes installed - $50/pair
Blitz Dual SBC Spec-S, includes solenoid, all wiring looms - $350 ono
Return flow FMIC & piping kit for R33 Skyline Gts-t - painted black.
Pretty good condition, but the lower return pipe & end tank has some scrapes on the under side - $250 pickup only
Turbosmart boost gauge & Greddy a-pillar mount, Sensational condition - $100 ono
Walbro GSS-342 500HP fuel pump & R33 Skyline cradle, ready to drop in - $100
2x (pair) Avantek 18x8" wheels & tyres. Wheels are in sensational condition, basically no scrapes/damage at all - $250
One of the tyres is as new has about ~90% read, the other one has some camber wear and is probably not roadworthy
Pedders lowered springs & Pedders comfort gas shocks all round. Great condition - $400 for the full set
Adjustable front castor rods - $75
HKS pod filter & 3" AFM adapter - $40
Blitz turbo timer & wiring loom - $30
5 speed manual rb25det gearbox - SOLD to a mate
Rb25DET engine - ran perfectly while in the car & had great compression - approx 155 psi on all 6 cylinders - $1000
Will be sold as a long motor - no turbocharger, loom, coilpacks or accesories (alt, p/s, a/c pump) but everything else is there
Exterior Stuff:
s2 front bar & foglights/indicators, has been cut for FMIC - $300 pickup only
s2 front grille - $60
s2 front reo bar - $120
s2 bonnet - $250
Front guards - $75 each
Bare nose cut/radiator support - $150
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts & matching rear pods - small crack/hole in one side - $120 - pickup only
Engine / Engine bay stuff:
Aircon condenser - $100
R33 radiator & shroud - $100
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $90
A/c condenser/thermo fan - $60
engine clutch fan - $60
S2 afm (pink sticker) - $70
standard BOV & crossover pipe - $50
Engine Mounts - $60/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $20
Brakes/driveline:
Front calipers, painted silver. Includes all pins/clips - $250
Rear calipers, painted silver. Includes all pins/clips - $120
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front lower control arms - $50 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $120 pair
Handbrake drum assembly incl cables - $120 pair
Rear differential (4.1) manual diff - $175
Driveshafts $75 pair
Spare space saver wheel - $50
Interior:
S2 steering wheel & airbag - Great condition, little/no wear - $150
Driver's side power window switch (12 pin) - $75
Driver's side power window switch surround plastic (s2) - $60
Passenger side window motor - $50
Drivers side window motor - $100
Instrument cluster, approx 168,000km, all gauges working well - $100
Instrument cluster dash surround (s2) - $80
Gear stick surround (s2) - $50
Centre console, with good lid/latch - $50
Seatbelts (full set) - $75
Ignition barrel + door barrels & key - $90
on your kakimoto catback, on the pipes (not the cannon) is there a small rectangular plate with something like a product ID, perhaps starting with N----------- ???
PMs replied. Engine loom, p/s pump, front seats sold, Exhaust sold pending payment.
The adjustable castor rods are Tein, pictured below
Few more photos:
Pedders suspension:
Tein adjustable castor rods:
Sideskirts/pods
Hey mate.
How much for the boost gauge or cup without gauge and cigarette lighter socket?
What suburb is pickup? I might be interested in boot lining stuff if you have it in great condition too.
Cheers
-Steve
Hey mate.
Cheers
-Steve
PM sent & replied !
Hey can I see some pics of rotors on 0401957814?? Front and rear?
No worries, i'll message you a pic on thursday
Hi do you have red stop light for rear spoiler? if so how much? thanks Dennis 0403922737
Yes i've got one - $25? PM me if you're keen
Do you still have the front seats?
Sorry mate i'm hanging onto them
Can u post up what's been sold ?
Most of the front end- bonnet, front bar, headlights, reo bar, engine wiring loom, front LCAs, gearbox, tailshaft, front/rear seats, door trims, PBR clutch, 3" kakimito exhaust, dash surround, power steering pump - SOLD
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
