Hey ya'll, I've got a series 2 R33 Skyline Gts-t here in Sydney for wrecking. The car was running great with approx 168,00km on the clock, and only had some light suspension arm damage/guttered wheels at the rear, and some faded paint on the roof
Send me a PM or reply here if you're after anything here or any other random small parts. I'm located in Sydney for pickup or I can send most parts anywhere in Aus
Few more pics will be up during the week !
It had a few after market parts:
RPM / PBR Cushioned button clutch, pressure plate & recently machined flywheel, great condition, lots of meat left - $300
3" Kakimoto stainless steel catback exhaust, sensational condition - $300 pickup only
Front castor rods with near new urethane bushes installed - $50/pair
Blitz Dual SBC Spec-S, includes solenoid, all wiring looms - $350 ono
Return flow FMIC & piping kit for R33 Skyline Gts-t - painted black.
Pretty good condition, but the lower return pipe & end tank has some scrapes on the under side - $250 pickup only
Turbosmart boost gauge & Greddy a-pillar mount, Sensational condition - $100 ono
Walbro GSS-342 500HP fuel pump & R33 Skyline cradle, ready to drop in - $100
2x (pair) Avantek 18x8" wheels & tyres. Wheels are in sensational condition, basically no scrapes/damage at all - $250
One of the tyres is as new has about ~90% read, the other one has some camber wear and is probably not roadworthy
Pedders lowered springs & Pedders comfort gas shocks all round. Great condition - $400 for the full set
Adjustable front castor rods - $75
HKS pod filter & 3" AFM adapter - $40
Blitz turbo timer & wiring loom - $30
5 speed manual rb25det gearbox - SOLD to a mate
Rb25DET engine - ran perfectly while in the car & had great compression - approx 155 psi on all 6 cylinders - $1000
Will be sold as a long motor - no turbocharger, loom, coilpacks or accesories (alt, p/s, a/c pump) but everything else is there
Exterior Stuff:
s2 front bar & foglights/indicators, has been cut for FMIC - $300 pickup only
s2 front grille - $60
s2 front reo bar - $120
s2 bonnet - $250
Front guards - $75 each
Bare nose cut/radiator support - $150
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts & matching rear pods - small crack/hole in one side - $120 - pickup only
Engine / Engine bay stuff:
Aircon condenser - $100
R33 radiator & shroud - $100
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $90
A/c condenser/thermo fan - $60
engine clutch fan - $60
S2 afm (pink sticker) - $70
standard BOV & crossover pipe - $50
Engine Mounts - $60/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $20
Brakes/driveline:
Front calipers, painted silver. Includes all pins/clips - $250
Rear calipers, painted silver. Includes all pins/clips - $120
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front lower control arms - $50 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $120 pair
Handbrake drum assembly incl cables - $120 pair
Rear differential (4.1) manual diff - $175
Driveshafts $75 pair
Spare space saver wheel - $50
Interior:
S2 steering wheel & airbag - Great condition, little/no wear - $150
Driver's side power window switch (12 pin) - $75
Driver's side power window switch surround plastic (s2) - $60
Passenger side window motor - $50
Drivers side window motor - $100
Instrument cluster, approx 168,000km, all gauges working well - $100
Instrument cluster dash surround (s2) - $80
Gear stick surround (s2) - $50
Centre console, with good lid/latch - $50
Seatbelts (full set) - $75
Ignition barrel + door barrels & key - $90
on your kakimoto catback, on the pipes (not the cannon) is there a small rectangular plate with something like a product ID, perhaps starting with N----------- ???
PMs replied. Engine loom, p/s pump, front seats sold, Exhaust sold pending payment.
The adjustable castor rods are Tein, pictured below
Few more photos:
Pedders suspension:
Tein adjustable castor rods:
Sideskirts/pods
Hey mate.
How much for the boost gauge or cup without gauge and cigarette lighter socket?
What suburb is pickup? I might be interested in boot lining stuff if you have it in great condition too.
Cheers
-Steve
Hey mate.
Cheers
-Steve
PM sent & replied !
Hey can I see some pics of rotors on 0401957814?? Front and rear?
No worries, i'll message you a pic on thursday
Hi do you have red stop light for rear spoiler? if so how much? thanks Dennis 0403922737
Yes i've got one - $25? PM me if you're keen
Do you still have the front seats?
Sorry mate i'm hanging onto them
Can u post up what's been sold ?
Most of the front end- bonnet, front bar, headlights, reo bar, engine wiring loom, front LCAs, gearbox, tailshaft, front/rear seats, door trims, PBR clutch, 3" kakimito exhaust, dash surround, power steering pump - SOLD
