Hey guys,
Been watching these forums for the last year or so and have learnt a lot from you guys...
I recently had to take my baby off the road because I blew my turbo and a few valve seals (crankcase breather hose got loose and melted on my exhaust)!
I've rebuilt my turbo at GCG and now looking to do some head work - the question I got for you skyline guru's out there - I've got 2 alternatives that I got quotes for..,
1. Head service (general) + port and polish (inc. replacement of valve train - oversized) priced between $1500 - $1800
OR
2. Head service (general) + extra for any part of the valve train that needs to be replaced + tomei 257 poncams priced between $1000 - $1300.
Which of the 2 options do you guys recommend I choose? (Unfortunately my budget does not allow me to do both)
Note: my current mods are as follows: microtech ecu, blitz boost controller, GCG highflow stage 2 turbo(rated @ 500hp), front mount intercooler, Bosch in tank fuel pump, jecs high flowed injectors, 3" turbo back exhaust, 100 cell high flow cat, pod filter + an atmospheric bov.
Thanking you guys in advance ;)
Edited by Skud1988
https://www.sau.com.au/forums/topic/429798-r33-gts-t-head-rebuild-question/
If you are just putting on a high flow and aiming for 260-300rwkw - Just service the head and put the rest of the money in your pocket.
Cost vs gain, you aren't going to see it. Spend money on brakes/suspension/tyres/clutch/diff or otherwise where you'll get far more bang for buck
  • Like 1
All I did with my head was get it cleaned up (sand blasted), Valve seats done, new valve guides and seals and cleaned the lifters
Added some Poncams and ready to go
If you don't mind answering, what power figures were you getting with that setup?
Engine isnt in the car yet
And that head setup will have little to do with the power figure, Turbo and supporting mods will really do more then basic head re-conditioning. The Cams will help a little but apart from that its all pretty standard
  • 7 months later...
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
