Hi Guys,
I'm needing to get either another clutch for the Stagea or I'm leaning towards getting the twin plate in it rebuilt.
I've tried to contact Jim Berry without success.
I dont know what brand it is currently in it.
Anyone able to tell me if they have had it done before and rough costs?
Thanks
Nick
https://www.sau.com.au/forums/topic/429811-clutch-needed/
Hi Guys,
Thanks
Nick
I had an os giken twin plate rebuilt.
place in St Mary's sydney.
cost about 1k.
https://www.sau.com.au/forums/topic/429811-clutch-needed/#findComment-6958038
Got myself a clutch from KB clutches in Sydney. Pretty sure Kat is running one from them and so is sweefu or stinky (one of those r31 guys)
Cost me $410 delivered and its holding up 250kw very well. Heavy duty organic
But if you tell him what you want he can make it
https://www.sau.com.au/forums/topic/429811-clutch-needed/#findComment-6958101
I had a kb in my 449kw gtr and on the most part it held strong through lots of track work and other shenanigans.
Also
K B Clutch Engineering
143 Coreen Ave, Penrith, NSW 2750
Outer West Sydney, Western Sydney p: 02 47321692
Speak to Keith, he's the man.
new 5 puk exedy that he bebuilds to your specs, 4000lb pressure plate and changed the pads to carbonic(?) all for $360 delivered
https://www.sau.com.au/forums/topic/429811-clutch-needed/#findComment-6958497
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
