Sure it's disgusting about the driver.
But what's makes me even more sick is everyone just wandering around, driving past, going to look and walking off, etc etc. no one even touches the old bloke to see if he's ok.
  • Like 1
It is not that no one gives a shit about the guy on the road... it is that people are affraid to help in case they find themselves in a court case for touching him... it has happened before in the US.
so it is lawyers and court systems that have helped create this issue... and not just the US either guys, it happens here also
  • Like 1
  • 1 month later...
I feel so sorry that that could have been me lying there with...
* No-one to take my pulse
* No-one to ask if I wanted someone to be contacted
* No-one to let me know that an ambo had been called
* No-one to just even hold my hand
that's a very terrible thought indeed Terry.
I'm trained in First Aid and when we had our class our trainer told us things are very different in the US and its also starting to happen here. He told us people feel violated if you help them and some people will threaten legal action. An example which happened in Australia he told us about, someone had passed out, had a heart attack. A first aid trained person was around and performed CPR and did the usual stuff. A rib was fractured and the guy who had the heart attack made a recovery then sued the person who helped him.
You do a good deed and some people will not see it like that. If I was there, sorry I would not touch the person, I would call an ambulance.
The driver in the other car(regardless of car), should have stayed. He was not at fault but leaving the scene was not a good move at all.
These days you try to do something good and you gotta think if its gonna swing back and bite you. I had a major car accident last year, plenty of other cars saw it. No one bothered to get out and ask if I needed help, no one bothered to come forward as a witness, no one bothered with anything.
Unfortunately this is true. I hear about these things all the time.
Yes the driver should have stayed. No questions about that.
It is sad we do live in a society (country is irrelevant) when even the person doing the right thing is held accountable.
An obvious example which is similar as mentioned is doctors/hospitals.
  • Like 1
To add to that, i myself have come forward as a witness to someone being hit by a car, and i said i would never do it again...
i was treated very poorly by the police and the whole process was rediculous... i had to take time off work at my expense, back then i was casual, to make reports, then to go to court for 2 days just in case i was called, to then be asked one question, then recieve 'compensation' of $40 for all the hours i lost from work and uni...
so what did i get for helping out, a slap in the face as far as i am concerned, i know it is the right thing to do and help, but when they make you feel like a criminal and it starts to cost you income and stress on how to pay bills it makes you think twice the second time....
  • Like 1
It still boils to doing what is right!
And there's a chasm of difference between doing what is right Vs doing only enough to not put yourself at threat and rationalising it into a cozy justification.
Again in the U.S. many First Aid Courses involve a Plan B where you do not commit to CPR and thus, only do compressions.
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
    • I had my car model wrong on my Shannons insurance when i had my V36. didn't make a difference when i claimed a windscreen. Nightcrawler is a negative nancey 🤪
